[mapserver-dev] Python MapScript
Howard Butler howard at hobu.co
Mon Apr 9 06:48:17 PDT 2018
+1 to all of it, and I don't think you need an RFC to do any of it.
On Sat, Apr 7, 2018 at 1:29 PM, Seth G <sethg at geographika.co.uk> wrote:
> Hi list,
> I'd like to continue the push in cleaning up the Python MapScript bindings,  and getting a release to PyPi (for Python 2 and 3).
> There are a number of things that can be removed as part of this, but I'd like to get opinions, points of view, and clarifications on a few things.
> - as I understand it the GD rendered has been removed since v7.0 of MapServer. This means the "USE_GD" flag will always be 0, and therefore the pygdioctx additional code can be removed? https://github.com/mapserver/mapserver/blob/master/mapscript/python/pygdioctx/pygdioctx.h#L50
> - cmake is now used to build the Python bindings so (please correct any incorrect assumptions) all the custom code in https://github.com/mapserver/mapserver/blob/master/mapscript/python/setup.py is now redundant, and a much simpler setup.py can be written to create wheels to upload to PyPI.
> - Python3 bindings only seem to work correctly with newer versions of SWIG. Is there any minimum we need to support? The C# ones only seem to compile with 1.3.x - but fixing this doesn't seem insurmountable. Ideally we can say only v3+ is officially supported.
> - The Python MapScript README is now 11 years old and refers to Python 2.2 - this can be extensively rewritten, and published as part of a PyPI release.
> Does the above warrant a RFC?
> Regards,
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
