[mapserver-dev] Python MapScript
Seth G sethg at geographika.co.uk
Tue Apr 10 10:43:37 PDT 2018
Thanks all for the support. The full test suite is being resurrected which will help check which parts of the API have changed from the docs (thanks to @claudep - see https://github.com/mapserver/mapserver/pull/5572).
One question it would be good to get input on is for versioning. In PyPI you can only change deployment packages by changing version number.
I'd propose versioning following MapServer versioning (as the package will need to match the binaries), with an additional descriptor at the end to allow for some beta releases and patches. This follows  PEP 440 guidelines [1].
e.g. 7.0.7a1, 7.0.7rc1, 7.0.7, 7.0.7.post1 etc.
Seth
[1] https://packaging.python.org/tutorials/distributing-packages/#standards-compliance-for-interoperability
web:http://geographika.co.uk
twitter: @geographika
On Tue, Apr 10, 2018, at 4:58 PM, Lime, Steve D (MNIT) wrote:
> Agree'd... No RFC necessary - especially since your talking about at
> least some documentation updates.
> As for Swig versions, swig 3.0 is almost 4 years old and would be a
> reasonable target IMHO. I'm assuming that the PHP7 bindings also require
> a newer version. Finding someone to adopt the C# bindings might be a
> challenge. It would be nice if all bindings compiled under 3.x as part
> of the 7.2 release.
> --Steve
> -----Original Message-----
> From: mapserver-dev [mailto:mapserver-dev-bounces at lists.osgeo.org] On
> Behalf Of Tom Kralidis
> Sent: Monday, April 09, 2018 4:27 PM
> To: Howard Butler <howard at hobu.co>
> Cc: mapserver-dev at lists.osgeo.org Mailing List <mapserver-
> dev at lists.osgeo.org>
> Subject: Re: [mapserver-dev] Python MapScript
> +1 echo Howard. Happy to help where I can on this one.
> ..Tom
> Sent from my iPhone
> > On Apr 9, 2018, at 09:48, Howard Butler <howard at hobu.co> wrote:
> > +1 to all of it, and I don't think you need an RFC to do any of it.
> >> On Sat, Apr 7, 2018 at 1:29 PM, Seth G <sethg at geographika.co.uk> wrote:
> >> Hi list,
> >> I'd like to continue the push in cleaning up the Python MapScript bindings,  and getting a release to PyPi (for Python 2 and 3).
> >> There are a number of things that can be removed as part of this, but I'd like to get opinions, points of view, and clarifications on a few things.
> >> - as I understand it the GD rendered has been removed since v7.0 of MapServer. This means the "USE_GD" flag will always be 0, and therefore the pygdioctx additional code can be removed? https://github.com/mapserver/mapserver/blob/master/mapscript/python/pygdioctx/pygdioctx.h#L50
> >> - cmake is now used to build the Python bindings so (please correct any incorrect assumptions) all the custom code in https://github.com/mapserver/mapserver/blob/master/mapscript/python/setup.py is now redundant, and a much simpler setup.py can be written to create wheels to upload to PyPI.
> >> - Python3 bindings only seem to work correctly with newer versions of SWIG. Is there any minimum we need to support? The C# ones only seem to compile with 1.3.x - but fixing this doesn't seem insurmountable. Ideally we can say only v3+ is officially supported.
> >> - The Python MapScript README is now 11 years old and refers to Python 2.2 - this can be extensively rewritten, and published as part of a PyPI release.
> >> Does the above warrant a RFC?
> >> Regards,
> >> Seth
> >> _______________________________________________
> >> mapserver-dev mailing list
> >> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
