[mapserver-dev] Improve label WRAP and WRAP regression
Oliver Tonnhofer olt at omniscale.de
Wed Aug 1 00:05:06 PDT 2018
just a heads-up. I've created a PR to fix the regression and to allow the user to add the Unicode ZERO WIDTH SPACE character in labels to signify possible wrap positions. These positions are independent of the WRAP character. This way you can wrap "Main-Road" and "Main Road" by adding a ZERO WIDTH SPACE after the space/dash. The ZERO WIDTH SPACE will not show up in the rendered output (whether wrapped or not).
You can insert this character with a PostGIS `replace` call. I'll add an example to the documentation.
The PR is at: https://github.com/mapserver/mapserver/pull/5634
I've included two questions:
• I've added a test. How do I generate the expected image? Most "result images perceptually match, though files differ" on my system.
• The patch is against master but I can rebase it. Where? branch-7-2? branch-7-3?
Regards,
Oliver
Oliver Tonnhofer  | Omniscale GmbH & Co KG  | https://omniscale.com
OpenStreetMap WMS and tile services         | https://maps.omniscale.com
> On 15. Jun 2018, at 13:05, Oliver Tonnhofer <olt at omniscale.de> wrote:
> Hi all,
> we want to improve label wrapping in MapServer so that road labels can be wrapped at space and dashes.
> I created an issue with a request for comments:
> https://github.com/mapserver/mapserver/issues/5613
> I also found a regression that is related to this:
> https://github.com/mapserver/mapserver/issues/5612
> Regards,
> Oliver
