[mapserver-dev] Testing PROJ 5.0.0 release candidates
Jeff McKenna jmckenna at gatewaygeomatics.com
Sat Feb 24 15:40:51 PST 2018
Update: MapServer and PROJ v5 were in fact reprojecting my test map, but
I was confused because (I was testing MS4W packages Mapbender and
GeoMOOSE demos) in fact the GeoMOOSE demo opening map was totally blank
(it should be a parcels line layer).  I went down rabbit holes trying to
find what was happening with PROJ v5 not displaying that data in
GeoMOOSE and MapServer......when in fact if I zoom out a bit the layer
is displayed properly (meaning the data extents have changed in the
displayed EPSG:3857 with PROJ v5).
I'll report to GeoMOOSE team.
Of course it could only be a mistake in my testing environment.
Sorry for all this noise here.
-jeff
On 2018-02-23 5:18 PM, Jeff McKenna wrote:
> Hi all,
> I am wondering if anyone else has tested the PROJ 5 release candidates
> (http://lists.maptools.org/pipermail/proj/2018-February/008045.html).  I
> am testing RC5 on Windows, with MapServer branch-7-0 and GDAL 2.2.3, and
> no problems with GDAL (reprojections with ogr2ogr etc), but any attempt
> to reproject with MapServer returns a blank map image and the following
> error in the logs:
> msProjectRect(): Projection library error. All points failed to reproject.
> Has anyone else tested this yet on any platforms?  Please let me know.
> Thanks,
> -jeff
