[mapserver-dev] MapServer 7.2.0 Beta 1 is Released
Daniel Morissette dmorissette at mapgears.com
Thu May 10 13:47:46 PDT 2018
I'm also +1 to proceed with PHP 7 support disabled to avoid delaying the
release any longer, and to re-enable it in a later release.
Daniel
On 2018-05-10 2:00 PM, Even Rouault wrote:
> On jeudi 10 mai 2018 17:54:16 CEST Lime, Steve D (MNIT) wrote:
>  > Well, I thought the work had been completed, but then again I'm not a PHP
>  > user at all and haven't paid that close of attention - other devs have
>  > traditionally led that charge. This came up as the beta was released. We
>  > have two ways to proceed:
>  > 1. PHP 7 support via SWIG -
>  > http://mapserver.org/development/rfc/ms-rfc-117.html. The RFC still shows
>  > draft status but there was a vote taken a little over a year ago and the
>  > RFC was accepted. Jeff will have to update folks on that work. I should
>  > have checked specifically ahead of the release - my fault.
>  > 2. PHP/MapScript support (native code) -
>  > https://github.com/mapserver/mapserver/issues/5252 and
>  > https://github.com/mapserver/mapserver/pull/5461. There's a pull request
>  > for that, it wasn't clear if it should be applied given the RFC for SWIG
>  > support. It appears like that still needs a bit of work and testing (and
>  > Window's compilation).
>  > I guess I'd prefer to pursue both ASAP. That way there's something
> for the
>  > longtime PHP/MapScript user and someone new. Again, I'm not a PHP or a
>  > Windows user so I'm not in a position to lead that work. Unless I'm
> missing
>  > something I don't see how either 1 or 2 can make it into 7.2.0 at this
>  > point and I don't want to delay 7.2 any further. I'd favor a short
>  > turnaround on a 7.2.1 or 7.4.0 release with PHP 7 support as the primary
>  > addition.
> I'm also supportive of not delaying 7.2 further because of that. There's
> already enough goodness in it.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
