[mapserver-dev] New MapScript API Docs
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Sep 16 02:32:30 PDT 2019
It's actually the main reason why I moved the entire MS4W community on
Windows (who hugely rely on the MapScripts: PHP/Python/Charp) to use
SWIG MapScript - so we can more easily maintain one set of MapScript
documents.  I saw that as the best way to move forward, for the few
document volunteers to easily maintain MapScript docs (not a separate
PHP document).   There have been some growing pains for this, but I'm
very glad this happened.
-jeff
On 2019-09-15 4:20 PM, Seth G wrote:
> Howard - thanks for the encouragement for the docs. I guess if MapScript
> is to be kept alive it may as well have up-to-date docs!
> I'm aware of the killing MapScript movement, and avoiding MapScript was
> the entire reason behind my writing the mappyfile library [1]. Sean
> Gillies who I believe was the last person to undertake significant
> MapScript changes finished up by writing the blog post "Stop Using
> MapScript"!
> On the other hand MapScript has proved useful to many people and all
> with little to no maintenance for the last 15 years, and SWIG is
> fortunately still being maintained with a new v4 release a few months ago.
> I've come to appreciate MapScript most in the following cases:
> - allowing high quality cartographic output as part of Python workflows,
> mainly using the `draw` functions in MapScript
> - as a second testing method for MapServer along with msautotest (via
> the Python test suite which now has > 300 tests)
> - allowing reuse of MapServer functions directly in a scripting language
> without having to jump out into the command line (legend generation,
> scalebars, querying and reusing connection configurations etc.).
> For Mapfile manipulation though I'd agree MapScript is far less useful
> than string templating and `fromstring` functions in the host language.
> Just to note - we have Andy to thank for setting up Perl MapScript tests
> earlier this year - https://github.com/mapserver/mapserver/pull/5778
> Andy - if you have any interest in setting up some more Perl typemaps or
> starting a Perl MapScript specific docs page let me know,
> Seth
> [1] https://mappyfile.readthedocs.io/
> [2] https://sgillies.net/2006/11/29/stop-using-mapscript.html
> web:http://geographika.co.uk
> twitter: @geographika
> On Sun, Sep 15, 2019, at 4:22 PM, Howard Butler wrote:
>>     Why do you want to kill MapScript?  I have poured everything into
>>     mapscript.
>> To kill MapScript is a running haha-but-serious joke I've had going
>> for a long time with some of the MapServer developers. My case to do
>> so is that MapScript has never been on par with mapfile and the
>> mapfile definition for specifying objects and their relationships.
>> Object lifetimes and their relationships were historically indefinite
>> and sometimes inconsistent in MapScript. Additionally, any backwards
>> compatibility considerations are often accommodated in mapfile, but
>> were not addressed consistently in MapScript.
>> In my opinion, language-specific implementations were better off to
>> use their own templating facilities and use the msLoad*FromString
>> capability. This recognizes that mapfile is the definition of how
>> MapServer renders images, it has validation of the object
>> relationships, and the project does its best to protect mapfile
>> compatibility as new versions are released.
>> Seth has done a ton of work on MapScript to fix all that and made
>> MapScript better than it ever was. All of his work means it will
>> probably never die :)
>> Howard
