[mapserver-dev] Proposed RFC 129: Update msautotest to use Pytest
Even Rouault even.rouault at spatialys.com
Mon Feb 3 04:05:48 PST 2020
Hi Jérome,
> I plan to work on SLD msautotests, following your valuable comments.
> Should I wait for this upgrade to be effective?
If you just add/modify .map tests, there's no impact.
If you want to add/modify things in msautotest/mspython, then yes, you'd
better wait a bit.
I'm submitting the RFC for approval right now in a new thread.
Even
http://www.spatialys.com
