[mapserver-dev] Possible bug to be reported ?
Seth G sethg at geographika.co.uk
Wed Jan 29 02:22:42 PST 2020
Hi Bruno,
I've got Python building with SWIG 4.0.1 - see the pull request at https://github.com/mapserver/mapserver/pull/5983
I've not tested Perl or PHP so any feedback on these welcome.
The Python issues are documented at https://github.com/mapserver/mapserver/issues/5982
Let me know how you get on,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Sun, Jan 26, 2020, at 9:12 AM, Bruno Friedmann wrote:
> Hi Seth, I'm still trying to understand what's wrong, but I've almost a zero
> knowledge about swig.
> Inside the buildroot in,
> build/mapscript/python/CMakeFiles/_pythonmapscript.dir/mapscriptPYTHON_wrap.c
> I've dicovered that notation obj[0] is present which remember me a patch made
> by an openSUSE fellow for gdal about this kind of trouble, not building with
> SWIG 4x.
> see https://github.com/OSGeo/gdal/pull/1819
> Any chance we have the same kind of problem here.
> On jeudi, 23 janvier 2020 11.20:37 h CET Seth G wrote:
> > Hi Bruno,
> > I recall running into this when testing the SWIG 4 beta and Python
> > MapScript. See SWIG mailing list post at
> > https://sourceforge.net/p/swig/mailman/message/36649157/ - it has the same
> > errors you have. I reverted to SWIG 3.0.12 to get it to build. If you get
> > any further debugging this please post back. Regards,
> > Seth
> > On Thu, Jan 23, 2020, at 9:22 AM, Bruno Friedmann wrote:
> > > Hi all, I would like to have your thought about a problem.
> > > During the building process of mapserver7 on openSUSE (especially our
> > > rolling flavor Tumbleweed).
> > > It use for the build actually gcc9 9.2.1 and swig 4.0.1
> > > I only build now only for python3 (version 3.7.3) the mapscript part
> > > I've got this type of error
> > > [  151s] make -f
> > > mapscript/python/CMakeFiles/_pythonmapscript.dir/build.make
> > > [  151s] make[2]: Entering directory '/home/abuild/rpmbuild/BUILD/
> > > mapserver-7.4.3/build'
> > > [  151s] [ 94%] Building C object mapscript/python/CMakeFiles/
> > > _pythonmapscript.dir/CMakeFiles/_pythonmapscript.dir/mapscriptPYTHON_wrap.
> > > c.o [  151s] cd
> > > /home/abuild/rpmbuild/BUILD/mapserver-7.4.3/build/mapscript/python
> > > && /usr/bin/cc -D_pythonmapscript_EXPORTS -I/home/abuild/rpmbuild/BUILD/
> > > -I/home/abuild/rpmbuild/BUILD/mapserver-7.4.3/renderec
> > > [  151s]
> > > /home/abuild/rpmbuild/BUILD/mapserver-7.4.3/build/mapscript/python/
> > > CMakeFiles/_pythonmapscript.dir/mapscriptPYTHON_wrap.c: In function
> > > 'imageObj_write':
> > > [  151s]
> > > CMakeFiles/_pythonmapscript.dir/mapscriptPYTHON_wrap.c:4020:28:
> > > warning:
> > > unused variable 'renderer' [-Wunused-variable]
> > > [  151s]  4020 |         rendererVTableObj *renderer = NULL;
> > > [  151s]       |                            ^~~~~~~~
> > > [  151s]
> > > '_wrap_CompositingFilter_filter_set':
> > > [  151s]
> > > CMakeFiles/_pythonmapscript.dir/mapscriptPYTHON_wrap.c:6617:66: error:
> > > expected expression before ',' token
> > > [  151s]  6617 |   if (!PyArg_ParseTuple(args,
> > > "Oz:CompositingFilter_filter_set", , &arg2)) SWIG_fail;
> > > [  151s]       |
> > > [  151s]
> > > '_wrap_clusterObj_region_set':
> > > [  151s]
> > > CMakeFiles/_pythonmapscript.dir/mapscriptPYTHON_wrap.c:7391:59: error:
> > > [  151s]  7391 |   if (!PyArg_ParseTuple(args,
> > > "Oz:clusterObj_region_set", ,
> > > &arg2)) SWIG_fail;
> > > [  151s]       |
> > > So my questions are, is somebody else have seen this (arch, fedora exp...)
> > > ? What is the root cause (will serve as subject for the issue).
> > > Is there a simple stupid fix (then I could try to write it, test and PR
> > > afterwards)
> > > Thanks for any pointer
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Bruno Friedmann
>  Ioda-Net Sàrl www.ioda-net.ch
>  GPG KEY : D5C9B751C4653227
>  irc: tigerfoot
