[mapserver-dev] Draft proposal for 8.0 - Site Context FIles
Steve Lime sdlime at gmail.com
Sat Apr 3 07:45:41 PDT 2021
> Why not calling this a configuration file ? I believe it would be
slightly clearer than context
Of course! I bounced around with a bunch of ideas in my head and missed the
most obvious one. I can
> Since MS 8.0 will include nlohmann/json, perhaps consider a JSON
configuration file rather than our historical mapfile-like syntax?
We could, I had thought about it... JSON allows the use of other
tools/validators and nlohmann is dead simple. That said, I don't know what
the tradeoffs would be in terms of making the JSON configuration object
available for use. Could it be hung off the mapObj? Would we have to
cpp-ify everything?
>  Regarding using putenv()
Need to review the exact use of each environment variable to see how they
are leveraged. Ideally it wouldn't be necessary. Where is
CPLSetConfigOption() storing the key/value pairs?
On Sat, Apr 3, 2021 at 6:37 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Steve,
> Excellent initiative. A few remarks:
> - Why not calling this a configuration file ? I believe it would be
> - Since MS 8.0 will include nlohmann/json, perhaps consider a JSON
> configuration file rather than our historical mapfile-like syntax ? This
> would allow to develop a json-schema for validation. Your example would
> become:
>   "env": {
>     "#comment": "put some comment here"
>     "MS_MAP_NO_PATH": "true"
>   "maps": {
>    "MAP1": "/opt/mapserver/myapp/map1.map",
>   "MAP2": "/opt/mapserver/myapp/map2.map"
> - Regarding using putenv(), I'm not sure this is a good idea in FastCGI
> mode, according to what is mentioned in
> http://web.mit.edu/wwwdev/man/man3/FCGI_Accept.3.  Using GDAL
> CPLSetConfigOption() instead of putenv() and CPLGetConfigOption() instead
> of getenv() would avoid messing with the "environ" global variable. (unless
> I'm wrong our CI doesn't test at all CGI / FastCGI ... I'll try to look at
> adding some testing of this)
> Even
> Le 02/04/2021 à 23:19, Steve Lime a écrit :
> Hi all: Just thinking about ways to make configuring MapServer easier for
> information you can't or don't want to manage in mapfiles. Currently that
> is done via environment variables. Another option would be the use of
> config/ini-type file. I've started a draft RFC for something I'll call a
> MapServer context file for the moment. See
> https://github.com/sdlime/mapserver/wiki/MapServer-8.0-Context-File for
> more information. Just floating an idea at this point...
> --Steve
> mapserver-dev mailing listmapserver-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/mapserver-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210403/9ff95527/attachment.html>
