[mapserver-dev] Reminder of upcoming 8.0 release plan dates
Even Rouault even.rouault at spatialys.com
Thu Apr 8 08:03:32 PDT 2021
I don't see a need for a 7.8 just to get PROJ 8 support. Just issuing a
7.6.3 from current 7.6 branch or cherry-picking the below patch in the
meantime should be enough.
Le 08/04/2021 à 16:11, Steve Lime a écrit :
> Perhaps a 7.8 makes sense in the context of Proj then and we could
> bundle the changes that require the use of certain environment
> variables with it. What would the preferred configs look like then (in
> terms of GDAL and PROJ versions)?
> --Steve
> On Wed, Apr 7, 2021 at 12:32 PM Even Rouault
> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>> wrote:
>     I've cherry-picked the trivial patch in the 7.6 release branch in:
>     https://github.com/MapServer/MapServer/commit/3c6f3f0963a03e4968dfdb886eb2d27ae12abfd6
>     <https://github.com/MapServer/MapServer/commit/3c6f3f0963a03e4968dfdb886eb2d27ae12abfd6>
>     Even
>     Le 07/04/2021 à 16:26, Sebastiaan Couwenberg a écrit :
>     > On 4/7/21 4:08 PM, Jeff McKenna wrote:
>     >> Please share your thoughts here.
>     > Please don't let feature creep prevent releasing the proj.h support.
>     > It's sad that an important OSGeo project like MapServer still has no
>     > release with PROJ 6 support.
>     > If you do keep pusing back MapServer 8, please release 7.8 with
>     just the
>     > changes for proj.h support ASAP.
>     > Kind Regards,
>     > Bas
>     http://www.spatialys.com <http://www.spatialys.com>
>     My software is free, but my time generally not.
>     _______________________________________________
>     mapserver-dev mailing list
>     mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>     <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210408/e1430350/attachment.html>
