[mapserver-dev] mapscriptng - classes all lower case?
Worth Lutz wal3 at mindspring.com
Thu Apr 29 14:54:15 PDT 2021
Jeff,
I found that file in /usr/lib64/php/modules along with php_mapscriptng.so.
It was using the same 4.0.1 SWIG.  The classes described there use
camelCase and not lowercase.
I'll look for more clues.
*Worth Lutz*
On 4/29/2021 4:00 PM, Jeff McKenna wrote:
> At the top of that file (around line 5) it should state what version
> of SWIG that was used to generate that file: in my case, for the
> Ubuntu server that I am checking, it is: 4.0.1  (MS4W uses
> master/4.1.0-dev)
> -jeff
> On 2021-04-29 4:46 p.m., Jeff McKenna wrote:
>> I have not seen that case before.  Once installed, you should find
>> the associated file (containing the MapServer constants and classes)
>> in a path something like:
>>    /usr/lib/php/xxx/mapscript.php
>> If you are using today's 'main' checkout, line ~2479 of mapscript.php
>> should list the "class mapObj" definition.
>> My servers are mostly Ubuntu, so I am not sure about RHEL8.
>> -jeff
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210429/2ac84a3a/attachment.html>
