[mapserver-dev] MapServer 8.0 Config File
Steve Lime sdlime at gmail.com
Thu Jul 8 07:43:36 PDT 2021
Hi Seth: I merged mapserver/main into my config branch and updated the
msLoadMap() signature to take a configObj *. It just creates a reference to
an immutable configObj that can be referenced as needed. I also updated
swiginc/map.i to take an optional second parameter. I haven't done anything
with msLoadMapFromString() as yet. I'll have to look at why tests are
failing but IMHO this should be stable enough to start doing some testing
if you wanted.
--Steve
On Thu, Jul 1, 2021 at 6:10 PM Steve Lime <sdlime at gmail.com> wrote:
> Yes, it’s stable although I haven’t changed function signatures for
> msLoadMap() in the C code so that probably should happen first.
> On Thu, Jul 1, 2021 at 2:07 AM Seth G <sethg at geographika.co.uk> wrote:
>> HI Steve,
>> I think that should be fine for all the MapScripts.
>> The C# ones have a second constructor [1], but this could ignore the
>> configObj, or have it as a third parameter.
>> Is https://github.com/MapServer/MapServer/pull/6303 stable enough to
>> create a SWIG configObj wrapper for testing?
>> Seth
>> [1]
>> https://github.com/MapServer/MapServer/blob/e48c5cb1fadec9b3f78b256e121093715b428c1a/mapscript/swiginc/map.i#L44
>> web:http://geographika.co.uk
>> twitter: @geographika
>> On Wed, Jun 30, 2021, at 7:54 PM, Steve Lime wrote:
>> Seth: Do you think this could be workable?
>>   $config = new mapscript::configObj('path to config file');
>>   $map = new mapscript::mapObj('my.map', $config);
>> Seems like we could update the MapScript mapObj constructors to take an
>> optional configObj parameter with default of NULL. Destroying a mapObj
>> doesn't destroy the config (it has a longer scope).
>> --Steve
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210708/f05dd716/attachment.html>
