[mapserver-dev] Question about the bad mapfile pattern (vulnerability) check
Steve Lime sdlime at gmail.com
Thu Feb 10 12:29:55 PST 2022
Patches welcomed! The config files do normalize site-level configuration
like this but yes, regexes can be daunting - although they are an important
part of configuration in a variety of ways, I don't know that we can
simplify things too much. My preferred approach is to use mapfile aliases
exclusively and get away from path filtering altogether.
On Thu, Feb 10, 2022 at 2:18 PM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> I suppose that is another performance hit.  So cancel that one, ha.
> Anyway, I do think it's good to discuss the issues, even if nothing else
> can be done.
> I'll continue to tackle this on the packaging side.
> -jeff
> On 2022-02-10 4:09 p.m., Jeff McKenna wrote:
> > For example (me thinking out of the box), could the MapServer config
> > file contain a section where users can specify paths or characters to
> > disallow (not a regular expression), and then MapServer would convert
> > that to a regular expression (in either PCRE or libregex syntax) and
> > apply it at run-time.
> > -jeff
> > On 2022-02-10 4:00 p.m., Jeff McKenna wrote:
> >> The tricky part here is that most recent packages use the PCRE regular
> >> expression library, because of its open BSD license, but the "bad"
> >> pattern hardcoded into the MapServer source is for libregex, which is
> >> GPL based, and that expression won't work with the PCRE engine.
> >> My thoughts were when the idea of a "MapServer config file" coming,
> >> was that phew, then users can just point to their valid mapfiles there
> >> with simple paths or even wildcard paths or directories, and we can
> >> completely remove that bad pattern stuff from the source code.
> >> So I assumed that the new config file would save us.  In fact the
> >> config file is just another place to put the bad pattern, which,
> >> honestly most MapServer users will never understand nor have the time
> >> to understand.
> >> I am wondering, when we re-look at the bad pattern stuff, if we can
> >> think of a way that the new config file can replace the hardcoding
> >> inside the MapServer source.
> >> I hope it's ok to wonder here out loud, ha.
> >> -jeff
> >> On 2022-02-10 3:05 p.m., Tamas Szekeres wrote:
> >>> Steve,
> >>> I think we cannot avoid to be platform dependent in this regard. A
> >>> single slash at the beginning on Windows systems should not be
> >>> accepted, because it can specify a relative path, however a double
> >>> back slash at the beginning is accepted (absolute path of a network
> >>> share). Currently the single slash at the beginning is accepted in
> >>> all platforms.
> >>> Applying environment variables might not be a trivial task in all run
> >>> time environments, so I think the default behavior should work in
> >>> that way which can do the right thing in most use cases.
> >>> Best regards,
> >>> Tamas
> >>> Steve Lime <sdlime at gmail.com <mailto:sdlime at gmail.com>> ezt írta
> >>> (időpont: 2022. febr. 10., Cs, 15:48):
> >>>     The idea was to limit things to local paths with no back references
> >>>     by default. We're not distinguishing between OSes in setting that
> >>>     pattern. It's possible it's a bit overzealous so we could tweak the
> >>>     default if that makes sense across operating systems. It can be
> >>>     overridden by environment variable (or within the config file) and
> >>>     could be turned off completely with an expression that will never
> >>> match.
> >>>     On Thu, Feb 10, 2022 at 4:34 AM Tamas Szekeres <
> szekerest at gmail.com
> >>>     <mailto:szekerest at gmail.com>> wrote:
> >>>         Hi Developers,
> >>>         I noticed that the double back slashes are excluded from the
> >>>         accepted mapfile pattern in one of the commits not too long ago
> >>>         according to security vulnerability reasons. The bad patten
> >>>         regex is now looking like:
> >>>         const char *ms_map_bad_pattern_default =
> >>>         "[/\\]{2}|[/\\]?\\.+[/\\]|,";
> >>>         Do we have a specific reason why we don't accept the double
> back
> >>>         slashes at the beginning of the mapfile path? This normally
> >>>         refers to a network share which is considered to be an absolute
> >>>         path, and our use cases are working like that extensively. I
> >>>         guess we wanted to exclude the relative paths basically, but it
> >>>         seems not to be that case.
> >>>         I'm also wondering if the double forward slashes at the
> >>>         beginning makes much sense to exclude, since I think that is
> >>>         treated as a single forward slash in the unix like systems
> which
> >>>         is normally accepted.
> >>>         Thanks,
> >>>         Tamas
> >>>         _______________________________________________
> >>>         MapServer-dev mailing list
> >>>         MapServer-dev at lists.osgeo.org
> >>> <mailto:MapServer-dev at lists.osgeo.org>
> >>>         https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> >>>         <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> co-founder of FOSS4G
> http://gatewaygeo.com/
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220210/964e2bd3/attachment-0001.html>
More information about the MapServer-dev mailing list
