[mapserver-dev] Mapserver assertion handling causing potential crashes
Even Rouault even.rouault at spatialys.com
Sat Feb 12 11:25:03 PST 2022
Hopefully https://github.com/MapServer/MapServer/pull/6477 should fix that
to use or not to use assert(), and where, is one of the many debates for
which devs will have different opinions :
https://stackoverflow.com/questions/1081409/why-should-i-use-asserts .
I'd say assert() are supposed to be used for conditions you don't
anticipate to happen in practice and thus for which you don't have a
plan if they occur (a good reason is because you can't test it and thus
the error handling might be broken because untested). Of course practice
sometimes/often later contradicts your theories, as the impossible has a
trend to occur more often than you'd like :-)
Even
Le 12/02/2022 à 19:49, Steve Lime a écrit :
> /ert( layer->layerinfo != N/
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220212/333ee6a7/attachment.html>
More information about the MapServer-dev mailing list
