[mapserver-dev] Mapserver assertion handling causing potential crashes
Lime, Steve D (MNIT) steve.lime at state.mn.us
Mon Feb 14 08:29:29 PST 2022
Hi Tamas: We currently are using Coverity for static scans. There’s a Github action/workflow that runs weekly (Sundays) on the main branch (https://github.com/MapServer/MapServer/actions/workflows/coverity-scan.yml) - although it failed yesterday owing to upgrades on the Coverity side of things. I need to read through the changes to understand what we need to change in our workflow. Obviously Coverity didn’t catch this particular problem. Having some overlap using separate tools might not be a bad thing. --Steve
From: MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> On Behalf Of Tamas Szekeres
Sent: Monday, February 14, 2022 10:07 AM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] Mapserver assertion handling causing potential crashes
This message may be from an external email source.
Do not select links or open attachments unless verified. Report all suspicious emails to Minnesota IT Services Security Operations Center.
As far as I can see such kind of issues can easily be detected by a static code analyzer tool like this: https://sonarcloud.io/<https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fsonarcloud.io%2F&data=04%7C01%7Csteve.lime%40state.mn.us%7C1fefb794372b41efde2308d9efd40348%7Ceb14b04624c445198f26b89c2159828c%7C0%7C0%7C637804517455122173%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=PdHAdrscwD6OykPMrEZBAJlmiy86D2v7jVODoJalCko%3D&reserved=0>
This seems to be free of use for any open source projects.
What do you think using such tools regularly as part of the continuous integration?
Best regards,
Tamas
Tamas Szekeres <szekerest at gmail.com<mailto:szekerest at gmail.com>> ezt írta (időpont: 2022. febr. 12., Szo, 21:26):
Even,
Thank you for the fix. I agree that assert does have it's own purpose (when debugging), but the code should never expect that assert will do anything to prevent the code to continue the execution (like what throwing an exception would do). So dereferencing a null pointer in the subsequent code without checking the pointer against null is prohibited.
Best regards,
Tamas
Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>> ezt írta (időpont: 2022. febr. 12., Szo, 20:25):
Hopefully https://github.com/MapServer/MapServer/pull/6477<https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FMapServer%2FMapServer%2Fpull%2F6477&data=04%7C01%7Csteve.lime%40state.mn.us%7C1fefb794372b41efde2308d9efd40348%7Ceb14b04624c445198f26b89c2159828c%7C0%7C0%7C637804517455122173%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=aEUqheVdwCvJCKv1%2FcxRQLadND3%2Bw%2FBXzDSrIzmFgro%3D&reserved=0> should fix that
to use or not to use assert(), and where, is one of the many debates for which devs will have different opinions : https://stackoverflow.com/questions/1081409/why-should-i-use-asserts<https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fstackoverflow.com%2Fquestions%2F1081409%2Fwhy-should-i-use-asserts&data=04%7C01%7Csteve.lime%40state.mn.us%7C1fefb794372b41efde2308d9efd40348%7Ceb14b04624c445198f26b89c2159828c%7C0%7C0%7C637804517455122173%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=NEfqfY3R9dyHf9PGzqgWfPhTRcexJ5EqPj4KwcYJGoE%3D&reserved=0> . I'd say assert() are supposed to be used for conditions you don't anticipate to happen in practice and thus for which you don't have a plan if they occur (a good reason is because you can't test it and thus the error handling might be broken because untested). Of course practice sometimes/often later contradicts your theories, as the impossible has a trend to occur more often than you'd like :-)
Even
Le 12/02/2022 à 19:49, Steve Lime a écrit :
ert( layer->layerinfo != N
http://www.spatialys.com<https://gcc02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.spatialys.com%2F&data=04%7C01%7Csteve.lime%40state.mn.us%7C1fefb794372b41efde2308d9efd40348%7Ceb14b04624c445198f26b89c2159828c%7C0%7C0%7C637804517455122173%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=X%2BKdBNOzHTRmpNiCch6pMzvLTLWPsx%2B9RW0WbSvcvnQ%3D&reserved=0>
MapServer-dev mailing list
MapServer-dev at lists.osgeo.org<mailto:MapServer-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-dev<https://gcc02.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fmapserver-dev&data=04%7C01%7Csteve.lime%40state.mn.us%7C1fefb794372b41efde2308d9efd40348%7Ceb14b04624c445198f26b89c2159828c%7C0%7C0%7C637804517455122173%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=kIpkbJOYs1jZZL9cb2tTYJzQDKA6SK%2BADhwaKYy%2Fe4s%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220214/56f775df/attachment-0001.html>
More information about the MapServer-dev mailing list
