[mapserver-dev] App crash in mapparser.y
Tamas Szekeres szekerest at gmail.com
Sat Feb 19 07:22:30 PST 2022
I'm not too familiar in the current parser/lexer implementation, but is
msTokenizeExpression and yyparse supposed to be protected by the same
parser lock in msEvalContext? Or if  msTokenizeExpression doesn't leave any
global variables behind, should yyparse be protected by it's own?
Thanks,
Tamas
Steve Lime <sdlime at gmail.com> ezt írta (időpont: 2022. febr. 19., Szo,
16:02):
> Requires and labelrequires aren’t operating at the feature level, rather
> the layer level so they definitely don’t support attribute binding. We’d
> need to whip up a test case to figure out a method to trap this. The
> workaround is to fix the expression. I mean, obviously we don’t want to
> crash but it’s never going to work if written as you suspect.
> On Sat, Feb 19, 2022 at 7:55 AM Tamas Szekeres <szekerest at gmail.com>
> wrote:
>> Hi Devs,
>> I got a crash log which shows that the access violation is happening in
>> the following location:
>> *mapserver!yylex+0x1b5 [e:\builds-t1\src\mapserver-intramaps\vc15x64\mapparser.y @ 858]
>> 		mapserver!yyparse+0x247 [e:\home\even\mapserver\mapserver\mapparser.c @ 1461]
>> 		mapserver!msEvalContext+0x178 [e:\builds-t1\src\mapserver-intramaps\maputil.c @ 442]
>> 		mapserver!msDrawVectorLayer+0xb0 [e:\builds-t1\src\mapserver-intramaps\mapdraw.c @ 918]
>> 		mapserver!msDrawLayer+0x3a3 [e:\builds-t1\src\mapserver-intramaps\mapdraw.c @ 813]
>> 		mapserver!msDrawMap+0x415 [e:\builds-t1\src\mapserver-intramaps\mapdraw.c @ 403]
>> 		mapscript!CSharp_mapObj_draw+0xd*
>> By looking into the corresponding code, the problem has happened in the
>> following location in yylex():
>> * case MS_TOKEN_BINDING_INTEGER:    token = NUMBER; ---->   (*lvalp).dblval = atof(p->shape->values[p->expr->curtoken->tokenval.bindval.index]);    break;*
>> In maputil.c the call stack location is here (msEvalContext):
>> *msTokenizeExpression(&e, NULL, NULL);  p.shape = NULL;  p.expr = &e;  p.expr->curtoken = p.expr->tokens; /* reset */  p.type = MS_PARSE_TYPE_BOOLEAN;----->  status = yyparse(&p);  msFreeExpression(&e);*
>> And in mapdraw.c
>> * /* TODO TBT: draw as raster layer in vector renderers */----->  annotate = msEvalContext(map, layer, layer->labelrequires);  if(map->scaledenom > 0) {    if((layer->labelmaxscaledenom != -1) && (map->scaledenom >= layer->labelmaxscaledenom)) annotate = MS_FALSE;    if((layer->labelminscaledenom != -1) && (map->scaledenom < layer->labelminscaledenom)) annotate = MS_FALSE;  }*
>> I'm not sure if the LABELREQUIRES option supports attribute binding
>> (probably not) and in that case the
>> p->expr->curtoken->tokenval.bindval.index would probably have undefined
>> value. I don't have any information about the corresponding LABELREQUIRES
>> expression , but if I assume it doesn't contain attribute binding, then
>> this crash might probably happen due to a missing parser lock around *yyparse(&p).
>> *What do you think about the problem and how could we work around this?
>> Thanks,
>> Tamas
>> MapServer-dev mailing list
>> MapServer-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220219/47bfabae/attachment-0001.html>
More information about the MapServer-dev mailing list
