[mapserver-dev] App crash in mapparser.y
Tamas Szekeres szekerest at gmail.com
Tue Feb 22 12:22:30 PST 2022
Hi Steve,
I've got the corresponding mapfile causing the crash, it looks like each
LABELREQUIRES expression has a corresponding layer with the same name. The
only thing I see is that some of the expressions contain brackets (either
in the expression and in the layer name) like so:
*LABELREQUIRES "[Height of Buildings (2013)]"*
Is that something that is considered as an attribute binding by the lexer?
The crash location is looking like:
*case MS_TOKEN_BINDING_DOUBLE:  case MS_TOKEN_BINDING_INTEGER:    token =
NUMBER;    (*lvalp).dblval =
atof(p->shape->values[p->expr->curtoken->tokenval.bindval.index]);
break;*
However the p->shape has been initialized to NULL (in msEvalContext),
definitely.
Thanks,
Tamas
Steve Lime <sdlime at gmail.com> ezt írta (időpont: 2022. febr. 22., K, 15:21):
> Hi Tamas: Ok, reacquainting myself with that code. There are actually two
> lexers in play - msyylex() is the main one that is used to parse a mapfile
> and also expression strings - it is not thread-safe. With regards to
> expressions, msyylex() is used to generate a series of tokens - see
> msTokenizeExpression() in maplayer.c. There is a lock present when
> msyylex() is used as part of that function. The Bison parser has its own
> lexer (yylex(), defined in mapparser.y) that is used to traverse the series
> of tokens. That function (and yyparse()) operate on a parseObj that fully
> encapsulates expression evaluation. So the parser should be reentrant...
> Assuming that LABELREQUIRES is in play here, the simplest explanation is
> that its value contains a bad layer name in the expression. That would
> leave something like "[badlayer]" remaining in the string passed to
> msTokenizeString() and would result in the error you noted originally. We
> could/should add a check in msEvalContext() to examine the expression
> string to catch this condition. Using strchr to check for remaining '[' or
> ']' characters would probably do it.
> --Steve
> On Sat, Feb 19, 2022 at 12:19 PM Tamas Szekeres <szekerest at gmail.com>
> wrote:
>> Hi Steve,
>> According to the call stack below, yyparse also calling yylex internally,
>> which is not considered to be reentrant I think.
>> *mapserver!yylex+0x1b5 [e:\builds-t1\src\mapserver-intramaps\vc15x64\mapparser.y @ 858]
>> mapserver!yyparse+0x247 [e:\home\even\mapserver\mapserver\mapparser.c @ 1461]
>> mapserver!msEvalContext+0x178 [e:\builds-t1\src\mapserver-intramaps\maputil.c @ 442]*
>> Best regards,
>> Tamas
>> Steve Lime <sdlime at gmail.com> ezt írta (időpont: 2022. febr. 19., Szo,
>> 17:53):
>>> I thought generating tokens for an expression needed a lock since it
>>> uses the lexer but that the parser did not. I could be wrong though.
>>> On Sat, Feb 19, 2022 at 10:21 AM Steve Lime <sdlime at gmail.com> wrote:
>>>> I don’t remember offhand and will have to check. That said if there is
>>>> a attribute level token in a layer level expression than that would explain
>>>> your research. Is there really no way to get info on the expression(s) in
>>>> question?
>>>> On Sat, Feb 19, 2022 at 9:22 AM Tamas Szekeres <szekerest at gmail.com>
>>>> wrote:
>>>>> I'm not too familiar in the current parser/lexer implementation, but
>>>>> is msTokenizeExpression and yyparse supposed to be protected by the same
>>>>> parser lock in msEvalContext? Or if  msTokenizeExpression doesn't
>>>>> leave any global variables behind, should yyparse be protected by it's own?
>>>>> Thanks,
>>>>> Tamas
>>>>> Szo, 16:02):
>>>>>> Requires and labelrequires aren’t operating at the feature level,
>>>>>> rather the layer level so they definitely don’t support attribute binding.
>>>>>> We’d need to whip up a test case to figure out a method to trap this. The
>>>>>> workaround is to fix the expression. I mean, obviously we don’t want to
>>>>>> crash but it’s never going to work if written as you suspect.
>>>>>> On Sat, Feb 19, 2022 at 7:55 AM Tamas Szekeres <szekerest at gmail.com>
>>>>>> wrote:
>>>>>>> Hi Devs,
>>>>>>> I got a crash log which shows that the access violation is happening
>>>>>>> in the following location:
>>>>>>> 		mapserver!msDrawVectorLayer+0xb0 [e:\builds-t1\src\mapserver-intramaps\mapdraw.c @ 918]
>>>>>>> 		mapserver!msDrawLayer+0x3a3 [e:\builds-t1\src\mapserver-intramaps\mapdraw.c @ 813]
>>>>>>> 		mapserver!msDrawMap+0x415 [e:\builds-t1\src\mapserver-intramaps\mapdraw.c @ 403]
>>>>>>> 		mapscript!CSharp_mapObj_draw+0xd*
>>>>>>> By looking into the corresponding code, the problem has happened in
>>>>>>> the following location in yylex():
>>>>>>> * case MS_TOKEN_BINDING_INTEGER:    token = NUMBER; ---->   (*lvalp).dblval = atof(p->shape->values[p->expr->curtoken->tokenval.bindval.index]);    break;*
>>>>>>> In maputil.c the call stack location is here (msEvalContext):
>>>>>>> *msTokenizeExpression(&e, NULL, NULL);  p.shape = NULL;  p.expr = &e;  p.expr->curtoken = p.expr->tokens; /* reset */  p.type = MS_PARSE_TYPE_BOOLEAN;----->  status = yyparse(&p);  msFreeExpression(&e);*
>>>>>>> And in mapdraw.c
>>>>>>> * /* TODO TBT: draw as raster layer in vector renderers */----->  annotate = msEvalContext(map, layer, layer->labelrequires);  if(map->scaledenom > 0) {    if((layer->labelmaxscaledenom != -1) && (map->scaledenom >= layer->labelmaxscaledenom)) annotate = MS_FALSE;    if((layer->labelminscaledenom != -1) && (map->scaledenom < layer->labelminscaledenom)) annotate = MS_FALSE;  }*
>>>>>>> I'm not sure if the LABELREQUIRES option supports attribute binding
>>>>>>> (probably not) and in that case the
>>>>>>> p->expr->curtoken->tokenval.bindval.index would probably have undefined
>>>>>>> value. I don't have any information about the corresponding LABELREQUIRES
>>>>>>> expression , but if I assume it doesn't contain attribute binding, then
>>>>>>> this crash might probably happen due to a missing parser lock around *yyparse(&p).
>>>>>>> *What do you think about the problem and how could we work around
>>>>>>> this?
>>>>>>> Thanks,
>>>>>>> Tamas
>>>>>>> _______________________________________________
>>>>>>> MapServer-dev mailing list
>>>>>>> MapServer-dev at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220222/165df7b4/attachment.html>
More information about the MapServer-dev mailing list
