[MapServer-dev] Dropping support for PROJ <6 and GDAL <3
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Jun 5 13:42:37 PDT 2023
+1
(I know that I've recently had to modify our CI structure for changes in
both PHP and Python supported versions - I'd like to start a document
listing all of these supported library versions, likely at the MapServer
repository root, which will be easy to find for the user [especially as
8.2.0 will have a cleaner repository structure, through issue #6937 ]
-jeff
On 2023-06-03 12:15 p.m., Even Rouault wrote:
> Hi,
> I've prepared 2 pull requests
> https://github.com/MapServer/MapServer/pull/6900 and
> https://github.com/MapServer/MapServer/pull/6901 to respectively drop
> support for PROJ < 6 and GDAL < 3 for MapServer 8.2
> Any opposition to that?
> Those older versions haven't been supported anymore and for a long time
> by their respective projects, the proposed minimal versions have been
> released 4 years ago and our CI doesn't test the dropped versions
> anymore, so I believe it is safe to proceed.
> The PROJ < 6 drop removes quite a bunch of code paths so it is a nice
> cleanup. The GDAL < 3 has modest impacts, but anyway having PROJ >= 6
> and GDAL < 3 doesn't make sense as this is a rather unsupported
> combination.
> Even
More information about the MapServer-dev mailing list
