[MapServer-dev] Dropping support for PROJ <6 and GDAL <3
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Mon Jun 5 23:40:59 PDT 2023
+1
-Jukka Rahkonen-
Lähettäjä: MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> Puolesta thomas bonfort
Lähetetty: tiistai 6. kesäkuuta 2023 9.40
Kopio: MapServer Dev Mailing List <mapserver-dev at lists.osgeo.org>
Aihe: Re: [MapServer-dev] Dropping support for PROJ <6 and GDAL <3
+1
thomas
On Sat, Jun 3, 2023 at 5:29 PM Even Rouault <even.rouault at spatialys.com<mailto:even.rouault at spatialys.com>> wrote:
I've prepared 2 pull requests
https://github.com/MapServer/MapServer/pull/6900 and
https://github.com/MapServer/MapServer/pull/6901 to respectively drop
support for PROJ < 6 and GDAL < 3 for MapServer 8.2
Any opposition to that?
Those older versions haven't been supported anymore and for a long time
by their respective projects, the proposed minimal versions have been
released 4 years ago and our CI doesn't test the dropped versions
anymore, so I believe it is safe to proceed.
The PROJ < 6 drop removes quite a bunch of code paths so it is a nice
cleanup. The GDAL < 3 has modest impacts, but anyway having PROJ >= 6
and GDAL < 3 doesn't make sense as this is a rather unsupported combination.
Even
http://www.spatialys.com<http://www.spatialys.com/>
MapServer-dev mailing list
MapServer-dev at lists.osgeo.org<mailto:MapServer-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20230606/bf12a804/attachment.htm>
More information about the MapServer-dev mailing list
