[MapServer-dev] Dropping support for PROJ <6 and GDAL <3
Tamas Szekeres szekerest at gmail.com
Tue Jun 6 02:56:50 PDT 2023
+1
Tamas
Even Rouault <even.rouault at spatialys.com> ezt írta (időpont: 2023. jún. 3.,
Szo, 17:29):
> Hi,
> I've prepared 2 pull requests
> https://github.com/MapServer/MapServer/pull/6900 and
> https://github.com/MapServer/MapServer/pull/6901 to respectively drop
> support for PROJ < 6 and GDAL < 3 for MapServer 8.2
> Any opposition to that?
> Those older versions haven't been supported anymore and for a long time
> by their respective projects, the proposed minimal versions have been
> released 4 years ago and our CI doesn't test the dropped versions
> anymore, so I believe it is safe to proceed.
> The PROJ < 6 drop removes quite a bunch of code paths so it is a nice
> cleanup. The GDAL < 3 has modest impacts, but anyway having PROJ >= 6
> and GDAL < 3 doesn't make sense as this is a rather unsupported
> combination.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20230606/9d4479bf/attachment.htm>
More information about the MapServer-dev mailing list
