[MapServer-dev] Zero-size SVG rendering : mapserv.fcgi crashes
Philippe Ghesquiere philippe.ghesquiere at airbus.com
Wed Nov 15 07:16:49 PST 2023
Hi Jeff,
I opened ticket #6967 <https://github.com/MapServer/MapServer/issues/6967>.
Philippe
On Mon, Nov 13, 2023 at 2:51 PM Jeff McKenna via MapServer-dev <
mapserver-dev at lists.osgeo.org> wrote:
> Hi Philippe,
> Yes please open a ticket with your suggested changes.
> thanks,
> -jeff
> On 2023-11-13 6:21 a.m., Philippe Ghesquiere wrote:
> > Hi Jeff,
> > I'm afraid I will not be able to make a pull request by myself : I have
> > no development environment at hand.
> > Do you want me to open an issue ?
> > Sincerely
> > Philippe
> > On Fri, Nov 10, 2023 at 6:39 PM Jeff McKenna via MapServer-dev
> > <mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>>
> > wrote:
> >     Hi Philippe,
> >     Your dimensions test makes sense to me.  Are you willing to submit a
> >     pull request for this, against the main branch?  Also, it would be
> >     great
> >     if you can include a test for this in msautotest (follow steps at
> >     https://mapserver.org/development/tests/autotest.html
> >     <https://mapserver.org/development/tests/autotest.html> ) as part of
> >     your
> >     pull request.
> >     Thanks,
> >     -jeff
> >     Jeff McKenna
> >     GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
> >     co-founder of FOSS4G
> >     http://gatewaygeo.com/ <http://gatewaygeo.com/>
> >     On 2023-11-10 11:40 a.m., Philippe Ghesquiere via MapServer-dev
> wrote:
> >      > Hi all,
> >      > My mapserver installation is based on :
> >      >   * Mapserver 7.6.3
> >      >   * MapCache : 1.12.0
> >      > I bumped into a configuration (zoom, orientation, ...) where an
> SVG
> >      > symbol has one null dimension (height or width).
> >      > The rendering process crashes with the following error message
> >      > (mapcairo.c
> >      > <https://github.com/MapServer/MapServer/blob/rel-7-6-3/mapcairo.c
> >     <https://github.com/MapServer/MapServer/blob/rel-7-6-3/mapcairo.c>>)
> >      > mapserv.fcgi:
> >     /builds/i4d/datacenter/mapserver/MapServer/mapcairo.c:1074:
> >      > msRenderRasterizedSVGSymbol: Assertion
> >     `svg_cache->pixmap_buffer->height
> >      > && svg_cache->pixmap_buffer->width' failed.
> >      > The code snippet  shows :
> >      > //already rendered at the right size and scale? return
> >      > if(svg_cache->scale != style->scale || svg_cache->rotation !=
> >      > style->rotation) {
> >      > assert(svg_cache->pixmap_buffer->height &&
> >     svg_cache->pixmap_buffer->width);
> >      > Instead of crashing the rendering process, wouldn't it be more
> >      > appropriate to test buffer dimensions beforehands.
> >      > Something like :
> >      > if ( (svg_cache->pixmap_buffer->height == 0 ||
> >      > (svg_cache->pixmap_buffer->width == 0) )
> >      >     return MS_FAILURE;
> >      > style->rotation) {
> >      > Philippe
> >      > The information in this e-mail is confidential. The contents may
> >     not be
> >      > disclosed or used by anyone other than the addressee. Access to
> this
> >      > e-mail by anyone else is unauthorised.
> >      > If you are not the intended recipient, please notify Airbus
> >     immediately
> >      > and delete this e-mail.
> >      > Airbus cannot accept any responsibility for the accuracy or
> >     completeness
> >      > of this e-mail as it has been sent over public networks. If you
> >     have any
> >      > concerns over the content of this message or its Accuracy or
> >     Integrity,
> >      > please contact Airbus immediately.
> >      > All outgoing e-mails from Airbus are checked using regularly
> updated
> >      > virus scanning software but you should take whatever measures you
> >     deem
> >      > to be appropriate to ensure that this message and any attachments
> >     are
> >      > virus free.
> >     _______________________________________________
> >     MapServer-dev mailing list
> >     MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>
> >     https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> >     <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
> > The information in this e-mail is confidential. The contents may not be
> > disclosed or used by anyone other than the addressee. Access to this
> > If you are not the intended recipient, please notify Airbus immediately
> > Airbus cannot accept any responsibility for the accuracy or completeness
> > of this e-mail as it has been sent over public networks. If you have any
> > concerns over the content of this message or its Accuracy or Integrity,
> > All outgoing e-mails from Airbus are checked using regularly updated
> > virus scanning software but you should take whatever measures you deem
> > to be appropriate to ensure that this message and any attachments are
> > virus free.
> Jeff McKenna
The information in this e-mail is confidential. The contents may not be disclosed or used by anyone other than the addressee. Access to this e-mail by anyone else is unauthorised.
If you are not the intended recipient, please notify Airbus immediately and delete this e-mail.
Airbus cannot accept any responsibility for the accuracy or completeness of this e-mail as it has been sent over public networks. If you have any concerns over the content of this message or its Accuracy or Integrity, please contact Airbus immediately.
All outgoing e-mails from Airbus are checked using regularly updated virus scanning software but you should take whatever measures you deem to be appropriate to ensure that this message and any attachments are virus free.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20231115/c01d61a0/attachment.htm>
More information about the MapServer-dev mailing list
