[MapServer-dev] Removing remainings of GD from the documentation
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Nov 15 14:39:08 PST 2023
No reason (I had made sure to include warnings about this throughout).
I try hard to always include version notes in the documentation, as
users appreciate this.
If you wish to create a pull request of your changes I can merge (or
'squash').
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
On 2023-11-15 5:31 p.m., Rahkonen Jukka via MapServer-dev wrote:
> Hi,
> Is there any reason to keep references to GD renderer in the
> documentation? One example: https://mapserver.org/mapfile/symbol.html
> <https://mapserver.org/mapfile/symbol.html>
> ANTIALIAS [true|false]
> Should TrueType fonts be antialiased. Only useful for GD (gif)
> rendering. Default is false. Has no effect for the other renderers
> (where anti-aliasing can not be turned off).
> Warning: GD support was removed in MapServer 7.0.
> Nobody can use that feature any more. Manuals for old versions are
> available from https://mapserver.org/download.html#docspreviousreleases
> <https://mapserver.org/download.html#docspreviousreleases>.
> -Jukka Rahkonen-
More information about the MapServer-dev mailing list
