AW: [Mapserver-inspire] MapServer and INSPIRE
Stephan Meißl stephan at meissl.name
Tue Oct 11 11:06:54 EDT 2011
Edward,
sorry for my quite late response, I promise to be more responsive now
that this deadline I was working on is over.
The main points are to check the usage of metadata keys (syntax for
keys, reporting of missing keys, etc.) and the arbitrary grouping of
layers to any depth.
One point where we definitely would need some help is in testing and
test data. During the summer of code project we asked for some real
world demo datasets for the msautotest test suite but so far we don't
have any. Could you maybe help out here?
Thanks,
Stephan
On Thu, 2011-09-29 at 10:57 +0200, Nash, Edward wrote:
> Hi Stephan,
> have you got some documentation of exactly what the adjustments are which have been identified?
> We can't help with funding, but we could put some developer time into this to get it moving forward - others may be in a similar position. We'd rather put our time into something which is going in the "right" direction though, rather than just producing patches which are good enough to do a job for us but otherwise disappear into trac never to make it to trunk.
> Regards,
> Edward
> -----Ursprüngliche Nachricht-----
> Von: mapserver-inspire-bounces at lists.osgeo.org [mailto:mapserver-inspire-bounces at lists.osgeo.org] Im Auftrag von Stephan Meißl
> Gesendet: Dienstag, 27. September 2011 14:49
> An: Martin Kofahl
> Cc: mapserver-inspire at lists.osgeo.org
> Betreff: Re: [Mapserver-inspire] MapServer and INSPIRE
> All,
> Stefan did a great job in the summer-of-code project. However, the code
> needs some polishing here and there e.g. at the code sprint in Denver we
> discussed some adjustments that are needed.
> The major remaining part for full INSPIRE compatibility, as far as I
> understand, is the support for arbitrary grouping of layers to any
> depth. I need to take a closer look at ticket #1632 to seriously
> calculate the remaining work.
> Anyway, we'd definitely be willing to look into this but some funding
> would be very much appreciated :).
> cu
> Stephan
> On Tue, 2011-09-27 at 13:59 +0200, Martin Kofahl wrote:
> > Thomas,
> > can you give an outline about remaining work? I see union layers finished, concept for multilingualism existing, ...
> > Kind regards,
> > Martin
> > -------- Original-Nachricht --------
> > > Datum: Mon, 26 Sep 2011 17:38:33 +0200
> > > Von: thomas bonfort <thomas.bonfort at gmail.com>
> > > An: "Passmore, James H." <jpass at bgs.ac.uk>
> > > CC: "mapserver-inspire at lists.osgeo.org" <mapserver-inspire at lists.osgeo.org>
> > > James,
> > > trunk will be entering release-mode at the beginning of 2012, so the
> > > actual release would probably be around end of february.
> > > Speaking of inspire specifically, at the code sprint in Denver we came
> > > to the conclusion that we are in a rather desperate need of funding to
> > > finish off the work that was started during the summer-of-code program
> > > so that the inspire features can be cleanly integrated for the next
> > > release. If you or any other organization following this list is in a
> > > position to help with funding, please do speak up on this list so we
> > > can get this rolling. I would also imagine that an earlier release
> > > containing only the inspire improvements could be a possibility.
> > > best regards,
> > > thomas
> > > On Mon, Sep 26, 2011 at 17:27, Passmore, James H. <jpass at bgs.ac.uk> wrote:
> > > > I'm not sure if I ever believe the MapServer roadmap (or maybe I just
> > > don't understand what it's telling me).  Can anyone provide a heads up as
> > > when MapServer 6.2 might be released?  And importantly will it be the first
> > > WMS server software to support INSPIRE multi-lingual services?
> > > > thanks
> > > > James
> > > > -----Original Message-----
> > > > From: mapserver-inspire-bounces at lists.osgeo.org
> > > [mailto:mapserver-inspire-bounces at lists.osgeo.org] On Behalf Of Daniel Morissette
> > > > Sent: Monday, April 18, 2011 3:59 AM
> > > > To: mapserver-inspire at lists.osgeo.org
> > > > Subject: Re: [Mapserver-inspire] MapServer and INSPIRE
> > > > On 11-04-16 03:08 PM, Martin Kofahl wrote:
> > > >> Thanks to James, I could easily extend the GetCapabilities output for
> > > scenario 1 and focused on multi-language support for now. We could take
> > > advantage of MapServer variable substitution from url.
> > > >> Please take a look at
> > > http://trac.osgeo.org/mapserver/ticket/3608#comment:11
> > > > I see that you raised priority on the ticket, possibly in the hope that
> > > > we can fit this in 6.0? This caught the attention of the release
> > > > manager. ;-)
> > > > Unfortunately I think it's too late to put this in 6.0 and this should
> > > > be pushed to 6.2. Note that there are talks of doing a 6.2 in the summer
> > > > (definitely before FOSS4G) so the delay would not be too long. In the
> > > > meantime users who require this level of INSPIRE support could apply the
> > > > patch locally, but there are a few reasons why I think we should wait
> > > > until 6.2 for the official release of this code:
> > > > 1- We are way past the 6.0 feature freeze and this is clearly a new
> > > > feature and not a bug fix
> > > > 2- Unless I'm mistaken, this patch addresses only a subset of the
> > > > INSPIRE requirements and may not be compatible with a more complete
> > > > solution that would come in 6.2 to more widely address INSPIRE
> > > > requirements (what this mapserver-inspire group needs to work on)...
> > > > what I mean is that once something like this is released, it will be
> > > > nearly impossible to take it out, so I'd rather wait until we have a
> > > > solid solution instead of putting something in that we may have to take
> > > > back out later.
> > > > What do others think?
> > > > Daniel Morissette
> > > > http://www.mapgears.com/
> > > > Provider of Professional MapServer Support since 2000
> > > > _______________________________________________
> > > > Mapserver-inspire mailing list
> > > > Mapserver-inspire at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/mapserver-inspire
> > > > This message (and any attachments) is for the recipient only. NERC
> > > > is subject to the Freedom of Information Act 2000 and the contents
> > > > of this email and any reply you make may be disclosed by NERC unless
> > > > it is exempt from release under the Act. Any material supplied to
> > > > NERC may be stored in an electronic records management system.
More information about the Mapserver-inspire mailing list
