[Mapserver-inspire] MapServer and INSPIRE
Passmore, James H. jpass at bgs.ac.uk
Mon Sep 26 12:09:14 EDT 2011
Thomas,
Many thanks for your quick response.
I'm not sure if we will be able to fund any part of this important development, but I shall pass on the request.
Best regards
James
-----Original Message-----
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Monday, September 26, 2011 4:39 PM
To: Passmore, James H.
Cc: mapserver-inspire at lists.osgeo.org
Subject: Re: [Mapserver-inspire] MapServer and INSPIRE
James,
trunk will be entering release-mode at the beginning of 2012, so the
actual release would probably be around end of february.
Speaking of inspire specifically, at the code sprint in Denver we came
to the conclusion that we are in a rather desperate need of funding to
finish off the work that was started during the summer-of-code program
so that the inspire features can be cleanly integrated for the next
release. If you or any other organization following this list is in a
position to help with funding, please do speak up on this list so we
can get this rolling. I would also imagine that an earlier release
containing only the inspire improvements could be a possibility.
best regards,
thomas
On Mon, Sep 26, 2011 at 17:27, Passmore, James H. <jpass at bgs.ac.uk> wrote:
> I'm not sure if I ever believe the MapServer roadmap (or maybe I just don't understand what it's telling me).  Can anyone provide a heads up as when MapServer 6.2 might be released?  And importantly will it be the first WMS server software to support INSPIRE multi-lingual services?
> thanks
> James
> From: mapserver-inspire-bounces at lists.osgeo.org [mailto:mapserver-inspire-bounces at lists.osgeo.org] On Behalf Of Daniel Morissette
> Sent: Monday, April 18, 2011 3:59 AM
> To: mapserver-inspire at lists.osgeo.org
> On 11-04-16 03:08 PM, Martin Kofahl wrote:
>> Thanks to James, I could easily extend the GetCapabilities output for scenario 1 and focused on multi-language support for now. We could take advantage of MapServer variable substitution from url.
>> Please take a look at http://trac.osgeo.org/mapserver/ticket/3608#comment:11
> I see that you raised priority on the ticket, possibly in the hope that
> we can fit this in 6.0? This caught the attention of the release
> manager. ;-)
> Unfortunately I think it's too late to put this in 6.0 and this should
> be pushed to 6.2. Note that there are talks of doing a 6.2 in the summer
> (definitely before FOSS4G) so the delay would not be too long. In the
> meantime users who require this level of INSPIRE support could apply the
> patch locally, but there are a few reasons why I think we should wait
> until 6.2 for the official release of this code:
> 1- We are way past the 6.0 feature freeze and this is clearly a new
> feature and not a bug fix
> 2- Unless I'm mistaken, this patch addresses only a subset of the
> INSPIRE requirements and may not be compatible with a more complete
> solution that would come in 6.2 to more widely address INSPIRE
> requirements (what this mapserver-inspire group needs to work on)...
> what I mean is that once something like this is released, it will be
> nearly impossible to take it out, so I'd rather wait until we have a
> solid solution instead of putting something in that we may have to take
> back out later.
> What do others think?
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
> Mapserver-inspire mailing list
> Mapserver-inspire at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-inspire
> This message (and any attachments) is for the recipient only. NERC
> is subject to the Freedom of Information Act 2000 and the contents
> of this email and any reply you make may be disclosed by NERC unless
> it is exempt from release under the Act. Any material supplied to
> NERC may be stored in an electronic records management system.
More information about the Mapserver-inspire mailing list
