AW: AW: AW: [Mapserver-inspire] MapServer and INSPIRE
Martin Kofahl M.Kofahl at gmx.net
Thu Jan 5 08:49:46 EST 2012
Hi Stephan,
handling of wms_layer_group looks ok. I did test GetMap and GetFeatureInfo. Now it's much easier to configure full featured groups. However, I did not alter the inspirevs_test service, because it looks as inspire view service may not have named groups. I did post a question on the inspire forum. See http://inspire-forum.jrc.ec.europa.eu/mod/groups/topicposts.php?topic=79913&group_guid=5205#34121.
One thing I miss regarding wms_layer_group is the possibility to configures an unnamed group, thus for structuring the capabilities only.
Regarding open ToDos, here are my favorites:
- I see GetLegendGraphic requests still not working: http://www.geodaten-mv.de/dienste/inspirevs_test?language=ger&version=1.3.0&service=WMS&request=GetLegendGraphic&sld_version=1.1.0&layer=TN.RailTransportNetwork.RailwayArea&format=image/png&STYLE=inspire_common:DEFAULT
- The testsuite I use expects Content-Type application/vnd.ogc.gml instead of text/xml for GML-GetFeatureInfo responses. This has to be verified.
- AuthorityURL and Identifier may be quired at rootlayer, too
- Map -> Web -> wms_metadataurl should be renamed to wms_inspiremetadaurl and Map -> Web -> wms_metadataurl should be available for the root layer.
- Handling of keywords should be revised. Instead of wms_inspire_keyword we should talk about wms_keywordvocabulary "ISO" and so parse wms_keywordlist and wms_keywordlist_ISO.
- Style Title should be multilingual, too.
I can start with the AuthorityURL and MetadataUrl topics. Someone who can investigate into the GetLegendGraphic problem?
Best regards,
Martin
-------- Original-Nachricht --------
> Datum: Tue, 03 Jan 2012 15:02:16 +0100
> Von: "Stephan Meißl" <stephan at meissl.name>
> An: "Nash, Edward" <E.Nash at dvz-mv.de>
> CC: "mapserver-inspire at lists.osgeo.org" <mapserver-inspire at lists.osgeo.org>
> Betreff: Re: AW: AW: AW: [Mapserver-inspire] MapServer and INSPIRE
> Hi Edward,
> finally I found some time to look into the test data and mapfile - this
> is really great, thanks a lot!
> I've added the test data and your mapfile adjusted to the current
> sandbox [1].
> Note that I've been working in the sandbox and implemented support for
> named group layers via "wms_layer_group" (see separate mail to the
> list). Could you maybe have a look at this implementation and see which
> of your ToDos still persist? I'd appreciate if we could share some tasks
> based on this ToDos. Thanks for your offer!
> cu
> Stephan
> [1] http://trac.osgeo.org/mapserver/changeset/12942
> On Fri, 2011-12-09 at 21:26 +0100, Nash, Edward wrote:
> > Hi Stephan & INSPIRE-listers,
> > my colleagues have been busy and have produced some test data which
> conform to the INSPIRE data specs for transport networks, slightly denormalised
> to get a sane table/file structure, and an accompanying (heavily
> commented) Mapfile for use with the current INSPIRE sandbox version. Furthermore we
> have put up a public demo view service based on this which we will endeavor
> to keep updated as the sandbox version is changed.
> > The ZIP archive of the data (Shapefiles, we thought these would be best
> for including in msautotest) is attached to ticket #3608, where the demo
> service and the Mapfile are also linked (see
> http://trac.osgeo.org/mapserver/ticket/3608#comment:17 from mko).
> > For the impatient, here are the direct links:
> > Demo view service: http://www.geodaten-mv.de/dienste/inspirevs_test
> > Mapfile for demo: http://www.geodaten-mv.de/dienste/inspirevs_test.map
> > Demo dataset:
> http://trac.osgeo.org/mapserver/raw-attachment/ticket/3608/inspirevs_tn.zip
> > The demo VS has been tested using two publicly available test suites;
> the results are documented in the header comments in the Mapfile, along with
> some TODOs. The most important of these to our mind are:
> > - the root layer and grouped layers should automatically be of type
> UNION, in order to better supply the required metadata.
> > - UNION layers should support multiple geometries in order to reduce the
> various GROUP/wms_layer_group configurations.
> > - MetadataURL and inspire_common:MetadataURL should be two different
> things, set separately (affects root layer / service metadata).
> > - Similarly, keyword_iso doesn't replace keywordlist.
> > - LegendURL and Identifier/AuthorityUrl for the root layer don't work.
> > There are also issues with the inheritance of attributes through the
> layer hierarchy, but these can probably be ignored as they are "features
> rather than bugs".
> > Let me know if this small set of test data is sufficient for the needs
> msautotest, or any other feedback on our results.
> > Regarding the further work required, much of it is in any case fairly
> straightforward and we currently have capacity to work some of these things
> ourselves - but naturally don't want to duplicate effort if you or someone
> else is already working on the same tasks. Maybe we can split the tasks up
> into packages (e.g. metadata, layer structure, etc.) and we'll take on a
> package to keep things moving along?
> > Regards,
> > Edward
> > -----Ursprüngliche Nachricht-----
> > Von: Stephan Meißl [mailto:stephan at meissl.name]
> > Gesendet: Dienstag, 8. November 2011 15:26
> > An: Nash, Edward
> > Cc: mapserver-inspire at lists.osgeo.org
> > Betreff: Re: AW: AW: [Mapserver-inspire] MapServer and INSPIRE
> > Edward,
> > thanks again for your answer and offer. If you could provide some test
> > data in the INSPIRE structure that would be great. We would include this
> > data in msautotest for some INSPIRE tests where you could verify the
> > results in turn.
> > Thanks,
> > Stephan
> > On Wed, 2011-11-02 at 11:57 +0100, Nash, Edward wrote:
> > > Hi Stephan,
> > > now it's my turn to be tardy - apologies.
> > > Unfortunately neither we nor our customers have any real world data
> which we can offer - however we could generate some data in the INSPIRE
> structures (e.g. transport networks) if this would be a viable alternative.
> > > We would be happy to look at checking the keys or the layers: we are
> familiar with the codebase and the specifications, and we don't expect any
> major surprises there. As previously written we could donate some time for
> this.
> > > Let me know if you want to take up any of these offers: I will get
> back to you sooner this time.
> > > Regards,
> > > Edward
> > > Gesendet: Dienstag, 11. Oktober 2011 17:07
> > > An: Nash, Edward
> > > Betreff: Re: AW: [Mapserver-inspire] MapServer and INSPIRE
> > > Edward,
> > > sorry for my quite late response, I promise to be more responsive now
> > > that this deadline I was working on is over.
> > > The main points are to check the usage of metadata keys (syntax for
> > > keys, reporting of missing keys, etc.) and the arbitrary grouping of
> > > layers to any depth.
> > > One point where we definitely would need some help is in testing and
> > > test data. During the summer of code project we asked for some real
> > > world demo datasets for the msautotest test suite but so far we don't
> > > have any. Could you maybe help out here?
> > > Thanks,
> > > Stephan
> > > On Thu, 2011-09-29 at 10:57 +0200, Nash, Edward wrote:
> > > > Hi Stephan,
> > > > have you got some documentation of exactly what the adjustments are
> which have been identified?
> > > > We can't help with funding, but we could put some developer time
> into this to get it moving forward - others may be in a similar position. We'd
> rather put our time into something which is going in the "right" direction
> though, rather than just producing patches which are good enough to do a
> job for us but otherwise disappear into trac never to make it to trunk.
> > > > Regards,
> > > > Edward
> > > > Von: mapserver-inspire-bounces at lists.osgeo.org
> [mailto:mapserver-inspire-bounces at lists.osgeo.org] Im Auftrag von Stephan Meißl
> > > > Gesendet: Dienstag, 27. September 2011 14:49
> > > > An: Martin Kofahl
> > > > Betreff: Re: [Mapserver-inspire] MapServer and INSPIRE
> > > > All,
> > > > Stefan did a great job in the summer-of-code project. However, the
> code
> > > > needs some polishing here and there e.g. at the code sprint in
> Denver we
> > > > discussed some adjustments that are needed.
> > > > The major remaining part for full INSPIRE compatibility, as far as I
> > > > understand, is the support for arbitrary grouping of layers to any
> > > > depth. I need to take a closer look at ticket #1632 to seriously
> > > > calculate the remaining work.
> > > > Anyway, we'd definitely be willing to look into this but some
> funding
> > > > would be very much appreciated :).
> > > > cu
> > > > Stephan
> > > > On Tue, 2011-09-27 at 13:59 +0200, Martin Kofahl wrote:
> > > > > Thomas,
> > > > > can you give an outline about remaining work? I see union layers
> finished, concept for multilingualism existing, ...
> > > > > Kind regards,
> > > > > Martin
> > > > > > Datum: Mon, 26 Sep 2011 17:38:33 +0200
> > > > > > Von: thomas bonfort <thomas.bonfort at gmail.com>
> > > > > > An: "Passmore, James H." <jpass at bgs.ac.uk>
> > > > > > James,
> > > > > > trunk will be entering release-mode at the beginning of 2012, so
> the
> > > > > > actual release would probably be around end of february.
> > > > > > Speaking of inspire specifically, at the code sprint in Denver
> we came
> > > > > > to the conclusion that we are in a rather desperate need of
> funding to
> > > > > > finish off the work that was started during the summer-of-code
> program
> > > > > > so that the inspire features can be cleanly integrated for the
> next
> > > > > > release. If you or any other organization following this list is
> in a
> > > > > > position to help with funding, please do speak up on this list
> so we
> > > > > > can get this rolling. I would also imagine that an earlier
> release
> > > > > > containing only the inspire improvements could be a possibility.
> > > > > > best regards,
> > > > > > thomas
> > > > > > On Mon, Sep 26, 2011 at 17:27, Passmore, James H.
> <jpass at bgs.ac.uk> wrote:
> > > > > > > I'm not sure if I ever believe the MapServer roadmap (or maybe
> I just
> > > > > > don't understand what it's telling me).  Can anyone provide a
> heads up as
> > > > > > when MapServer 6.2 might be released?  And importantly will it
> be the first
> > > > > > WMS server software to support INSPIRE multi-lingual services?
> > > > > > > thanks
> > > > > > > James
> > > > > > > -----Original Message-----
> > > > > > > From: mapserver-inspire-bounces at lists.osgeo.org
> > > > > > [mailto:mapserver-inspire-bounces at lists.osgeo.org] On Behalf Of
> Daniel Morissette
> > > > > > > Sent: Monday, April 18, 2011 3:59 AM
> > > > > > > To: mapserver-inspire at lists.osgeo.org
> > > > > > > Subject: Re: [Mapserver-inspire] MapServer and INSPIRE
> > > > > > > On 11-04-16 03:08 PM, Martin Kofahl wrote:
> > > > > > >> Thanks to James, I could easily extend the GetCapabilities
> output for
> > > > > > scenario 1 and focused on multi-language support for now. We
> could take
> > > > > > advantage of MapServer variable substitution from url.
> > > > > > >> Please take a look at
> > > > > > http://trac.osgeo.org/mapserver/ticket/3608#comment:11
> > > > > > > I see that you raised priority on the ticket, possibly in the
> hope that
> > > > > > > we can fit this in 6.0? This caught the attention of the
> release
> > > > > > > manager. ;-)
> > > > > > > Unfortunately I think it's too late to put this in 6.0 and
> this should
> > > > > > > be pushed to 6.2. Note that there are talks of doing a 6.2 in
> the summer
> > > > > > > (definitely before FOSS4G) so the delay would not be too long.
> In the
> > > > > > > meantime users who require this level of INSPIRE support could
> apply the
> > > > > > > patch locally, but there are a few reasons why I think we
> should wait
> > > > > > > until 6.2 for the official release of this code:
> > > > > > > 1- We are way past the 6.0 feature freeze and this is clearly
> a new
> > > > > > > feature and not a bug fix
> > > > > > > 2- Unless I'm mistaken, this patch addresses only a subset of
> the
> > > > > > > INSPIRE requirements and may not be compatible with a more
> complete
> > > > > > > solution that would come in 6.2 to more widely address INSPIRE
> > > > > > > requirements (what this mapserver-inspire group needs to work
> on)...
> > > > > > > what I mean is that once something like this is released, it
> will be
> > > > > > > nearly impossible to take it out, so I'd rather wait until we
> have a
> > > > > > > solid solution instead of putting something in that we may
> have to take
> > > > > > > back out later.
> > > > > > > What do others think?
> > > > > > > Daniel Morissette
> > > > > > > http://www.mapgears.com/
> > > > > > > Provider of Professional MapServer Support since 2000
> > > > > > > _______________________________________________
> > > > > > > Mapserver-inspire mailing list
> > > > > > > Mapserver-inspire at lists.osgeo.org
> > > > > > > http://lists.osgeo.org/mailman/listinfo/mapserver-inspire
> > > > > > > This message (and any attachments) is for the recipient only.
> NERC
> > > > > > > is subject to the Freedom of Information Act 2000 and the
> contents
> > > > > > > of this email and any reply you make may be disclosed by NERC
> unless
> > > > > > > it is exempt from release under the Act. Any material supplied
> to
> > > > > > > NERC may be stored in an electronic records management system.
More information about the Mapserver-inspire mailing list
