[Mapserver-inspire] default style name
Stephan Meißl stephan at meissl.name
Fri Nov 15 04:22:23 PST 2013
Johan,
if I'm not mistaken, styles are inherited. So if you have
"inspire_common:DEFAULT" at the root layer this style is available in
all layers.
cu
Stephan
On 11/15/2013 10:17 AM, Johan.Stalnacke at scb.se wrote:
> Hi,
> I’m having a hard time figuring out how to set the default style name so
> that both rootlayer and regular layers have ”inspire_common:default” at
> the same time
> The problem is:
> I’ve managed to set the layers default name with ”classgroup” and
> ”group” and the root layer with wms_layer_name in WEB.metadata one by
> one, but when I set them both at the same time, only root layer shows
> ”inspire_common:DEFAULT”. The other layers just shows ”default”.
> Is this a known issue or am I doing something wrong?
> Best regards
> Johan Stålnacke
> Statistics Sweden
More information about the Mapserver-inspire mailing list
