[Mapserver-inspire] default style name
Johan.Stalnacke at scb.se Johan.Stalnacke at scb.se
Fri Nov 15 04:43:25 PST 2013
Hi James,
Thank you!
Best regards
Johan Stålnacke
-----Ursprungligt meddelande-----
Från: Passmore, James H. [mailto:jpass at bgs.ac.uk]
Skickat: den 15 november 2013 13:35
Till: Stålnacke Johan RM/MN-S; mapserver-inspire at lists.osgeo.org
Ämne: RE: default style name
Hi Johan,
> From: mapserver-inspire-bounces at lists.osgeo.org [mailto:mapserver-
> inspire-bounces at lists.osgeo.org] On Behalf Of Johan.Stalnacke at scb.se
> Sent: Friday, November 15, 2013 9:17 AM
> To: mapserver-inspire at lists.osgeo.org
> Subject: [Mapserver-inspire] default style name
> I’m having a hard time figuring out how to set the default style name
> so that both rootlayer and regular layers have ”inspire_common:default”
> at the same time
Whilst it doesn't answer your question directly, you should note that you don't actually need to have a style called "inspire_common:default" for your inspire layers, though you might get that impression from reading the 'Technical Guidance for the implementation of INSPIRE View services'
Implementation requirement 42 of said technical guidance refers to article 14 of the:
'COMMISSION REGULATION (EU) No 1089/2010 of 23 November 2010 implementing Directive 2007/2/EC of the European Parliament and of the Council as regards interoperability of spatial data sets and services'
<cite>
Article 14
Portrayal
1. For the portrayal of spatial data sets using a view network service as specified in Commission Regulation No 976/2009 ( 1 ), the following shall be available:
(a) the layers specified in Annex II for the theme or themes the data set is related to;
(b) for each layer at least a default portrayal style, with as a minimum an associated title and a unique identifier.
2. For each layer, Annex II defines the following:
(a) a human readable title of the layer to be used for display in user interface;
(b) the spatial object type(s) that constitute the content of the layer.
</cite>
So really inspire_common:default is just another way of saying you need a default style!
Cheers
James Passmore
GIS and WWW Specialist
British Geological Survey,
Environmental Science Centre,
KEYWORTH,
United Kingdom,
NG12 5GG
Linked Data (vCard):http://data.bgs.ac.uk/ref/BritishGeologicalSurvey
Phone:+44 (0)115 936 3125
Fax:+44 (0)115 936 3200
jpass at bgs.ac.uk
http://www.bgs.ac.uk/
Skype:BGSjames
@nmtoken
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
More information about the Mapserver-inspire mailing list
