graduated color symbols and mapserver
Banister Trevor
TBanister at SpaceImaging.com
Mon Nov 8 18:47:30 EST 1999
I was able to solve this to some extent by using the following expressions.
I'm not a regex guru, so some of these could sub optimal.
<Big ole' Kludge>
Suppose your range of numbers is 0-59 and you want 3 zones
Some of these expressions overlap, but it looks like the code is written so
the first matching expression encountered is enforced.
Zone 1: 2 classes to handle 0-19
[0-9] Matches numbers from 0 to 9
[1-1][0-9] Matches numbers from 10 to 19
Zone 2: 1 class to handle 20-39
[2-3][0-9]
Zone 3: 1 class to handle 40-59
[4-5][0-9]
</Big ole' Kludge>
-----Original Message-----
From: Robert Chavez [mailto:rchavez at perseus.tufts.edu]
Sent: Monday, November 08, 1999 11:18 AM
To: mapserver-users at lists.gis.umn.edu
Subject: re: graduated color symbols and mapserver
You are right about the expressions, I haven't been able to come up with
anything that works. Pre/Re classification would be possible, but the
files I'm working with are between 30 and 80 meg -- the dbf files are
just too large to pre/re classify easily with the tools I have at hand.
I'm toying with the idea about fooling around with the code to add
numeric expressions -- to handle >,<,<=,>=, etc expressions. I'm not
sure how useful this would be to the majority of map server users, but
maybe it's something that could be incorporated into a future version?
Rob
>That's what classes are for. Each class has it's
>own symbolization. The hard part is the expression to use with ranges
of numbers. One easy thing to do is to pre-classify each shape in
arcview and then >use that column in mapserver class expressions.
>Steve
