multiple layer queries
Stephen Lime steve.lime at dnr.state.mn.us
Wed Nov 10 14:52:05 EST 1999
Sure, you can do this. Key is to use mode=nquery rather than simply
query.  You also have to how the mapserver builds a page when
multiple query results are present.
  - sends web- header (if defined)
  for each layer with query results
    - sends layer- header (if defined)
    for each result within a layer
      - sends query- template
    next result
    - sends layer- footer (if defined)
  next layer
  - sends web- footer (if defined)
Sorta like building a sandwich.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Michael Hass <mdh20 at axe.humboldt.edu> 11/10/99 01:41PM >>>
Hi all
I have the query the layer one at a time using a unique
template for each query down. Is there a way to combine
a query for multiple layers into one template, so that
by clicking on a point backed by a poly you could get
the results from both in one shot. I have tried coding it
in the mapfile/page but it ignores one and answers the other.
thanks
Mike Hass
