Plotting Symbols
Brent Fraser
bfraser at geoanalytic.com
Sun Nov 14 13:24:34 EST 1999
Kieran (and others),
Below is a typical set of entries
for symbolizing based on an attribute
value stored in the shapefile. The
CLASSITEM points to the column in
the DBF file, while the EXPRESSION
entry indicates the DBF value for
the CLASS. The CLASS entry defines
SYMBOL value to use in the symbol
set.
LAYER
NAME Rivers
TYPE POLYLINE
STATUS ON
DATA Alberta/psu/dnnetln_10TM
CLASSITEM DNLNTYPE
CLASS
NAME "Rivers"
EXPRESSION "1"
SYMBOL 0
COLOR 130 130 255
END
CLASS
NAME "Other Rivers"
EXPRESSION "5"
SYMBOL 1
COLOR 210 210 255
END
END # Layer
Your entries in your map file might
look like:
LAYER
NAME "My Points"
TYPE POINT
STATUS ON
DATA mypoints
CLASSITEM ynflag
CLASS
NAME "Yes"
EXPRESSION "Y"
SYMBOL 0
END
CLASS
NAME "No"
EXPRESSION "N"
SYMBOL 1
END
END # Layer
Brent
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Saturday, November 13, 1999 8:37 PM
Subject: Plotting Symbols
> Hi again,
> Could someone please give me a quick overview on the use of symbols for
> identifying points?
> The shape file I'm using has a text field in its .dbf that is a
> Yes/No/Other flag. ("Y", "N", and blank).
> How might I plot these points as symbols based on the contents of this
> flag field so that users could tell the difference when the data is put
> onto the gif output?
> Thanks much to all.
> Kieran
