targetting named frames
Stephen Lime
steve.lime at dnr.state.mn.us
Wed Nov 24 09:04:36 EST 1999
You have to use a touch of javascript to do this.
Basically when submitting the form you need to check the setting of mode and set the form target appropriately and then submit the form.
Steve
<<< "Ellis Robin (Bundaberg)" <Robin.Ellis at dnr.qld.gov.au> 11/23 8:33p >>>
Any ideas on how to send qeury results to a named frame in a new window?
I can currently return results in a new window by themselves, but I would
like to return this information in a "main" frame, with the same "header"
frame at the top.
I've tried to specify a named frame within the QUERY TEMPLATE section of the
map file but have had no success.
All help is appreciated.
Rob.
Robin Ellis
Land Resources Officer
Department of Natural Resources
Burnett District
ph: 07 4153 7843
fax: 07 4153 7823
