request for comments...
Cameron Shorter
cshorter at optusnet.com.au
Fri Oct 8 17:05:47 EDT 1999
Yes, I can see myself using such a feature. What I am working toward is an
interface to modify map shapes. The way I see it working is:
Split my web page into windows.
Window 1, the map window, contains a map. From this window, an operator can
select a feature (like a road), and all the details of that object are copied
to window 2. The operator can also enter a new feature, or update an old
feature by entering multiple points on the map window.
Window 2, the feature details window, contains all the vertex and data about
the selected feature. When the opertor has finished updating the feature,
they press the SUBMIT button and the details are sent to the database to be
updated.
Stephen Lime wrote:
> I'm in the midst of implementing a new feature for 3.3 called "query maps".
> In a nutshell they allow you to use the results of a query to generate a map.
> The constructor is very simple, you specify 3 parameters status, style and
> a hilite color (if necessary). I envision 3 styles of query maps:
> NORMAL - with this style the results of the query would be used to define
> a map extent and then the map would be draw as normal with no special
> attention payed to the query polygons. This would allow for item/value
> queries to generate a map in one step rather than the current two. Embedding
> maps if you know nothing about coordinates would be much easier this way.
> HILITE - the map would be drawn as normal, but features that are part of
> the query result set would be drawn using the hilite color. Very ArcView-ish.
> SELECTED - for queried layers, only those features that are part of the
> result set would be drawn. They would be rendered normally with no hilites.
> Especially useful with item/value queries. Non-query layers would be drawn
> as normal.
> Note that queries are limited to shapefiles only. Tiled data is not queryable.
> (Using perl and data from other sources will in effect give you query access
> to those sources since drawing is done feature by feature.)
> Anyway, I'd like to get comments from folks on this extension. Other ideas and
> so on. I can envision some very sophisticated apps just using what I've outlined
> above.
> Steve
> Stephen Lime
> Internet Applications Analyst
> MIS Bureau - MN DNR
> (651) 297-2937
> steve.lime at dnr.state.mn.us
