[beginner] Why does it look like a map of Arctic Snowfields?
Jason Domina
jdomina at ystone.mt.gov
Wed Sep 15 16:59:20 EDT 1999
Steve, Matt, Scott,
Thank you all very much for the suggestions. I think we're starting to track
the problem down, and I'm guessing it has to with how I compiled the mapserv
binary - hastily. Matt suggested:
> There is a stand-alone command that is called 'shp2gif' that is like a
> de-bugging command. It can be found in the ms_3.2 directory after
> installation.
> The syntax looks like this: shp2gif -m state.map -o state.gif
and when I run that on a one layer map file I get an error message claiming:
Error opening fontset /export/stlime/mapserv/ms_symbols/fonts/fonts.list
I have not created a font.list file. Where should I create it and how do I
tell mapserv where is located?
Jason
