Map server doesn't compile with TrueType support off
Banister Trevor
TBanister at SpaceImaging.com
Wed Sep 22 21:37:30 EDT 1999
I've been working on building a "license issue free" version of mapserver
without TTF and LZW gif support. I noticed that if you turn off TTF support
in the makefile you get a parse error when building it. I get the error on 3
platforms-- Linux (RedHat 6.x), Solaris 7, and cygwin.
Anyone have a fix for this? I've been trying code hacks, but nothing is
clicking yet.
Error detail:
gcc -c -Wall -O -DUSE_TIFF -I./regex -I./gd -I./shapelib maphash.c
In file included from maphash.c:1:
map.h:514: parse error before `fontSetObj'
map.h:516: parse error before `fontSetObj'
*** Error code 1
make: Fatal error: Command failed for target `maphash.o'
Trevor Banister, Sr. Application Designer
Space Imaging
12076 Grant Street
Thornton, CO 80241
Phone: (303) 254-2175 Fax: (303) 254-2211
"All the glossy brochures and PR budgets in the world can't disguise the
fact that nobody has solved the automatic programming problem. There is no
program that can take an English description of what you want done and turn
that into software." --Philip Greenspun
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/19990922/b921d5f5/attachment.html
