HTML templates with frames
Pierluigi Vittori
piero at innova.it
Sun Sep 26 06:08:29 EDT 1999
Hi all!
I am wondering if it is possible to use mapserv in a frameset environment, that
is if there is the possibility to update more than one html template at the same
time so that, for example, one can place the main map in one frame,
navigation arrows in another one, info in a third one and so on.
The problem that I see is that the placeholders in square brackets ([map],
[mapext] etc.) should be updated in more than one template file: is it
something the present version is already capable of handling? If not so, does
anybody see a way to implement it?
Thanks for your advice.
Piero
