what is polyline
imap at chesapeake.net imap at chesapeake.net
Fri Apr 14 06:47:11 EDT 2000
Markus,
I believe that
Polyline is  FROM, TO, TO, TO, TO, etc.
Use polyline for rendering outlines and polygons for fills.
You can do both like this:
LAYER
  NAME ctycu
  TYPE POLYGON
  STATUS ON
  DATA "ctyindex"
  CLASS
    SYMBOL 0
    OUTLINECOLOR 0 0 0
    COLOR 255 255 204
  END
END
Use both OUTLINECOLOR and COLOR for your CLASS item.
Later,
-Chris
Markus Spring wrote:
> Hi
> I tried to figure out what exactly is polyline.
> Is it true that
> * I can just display the outlines of a polygon rendered with a specified
> line symbol
> * but can not display polygons with fill and a specified outline
> If yes, then I don't know what's the difference to using TYPE LINE for a
> polygon shapefile.
> Any explanation, maybe example would be appreciated.
> Kind regards - markus
Chris Stuber (mapsurfer)
Silicon Mapping Solutions, Inc.
410-257-3187
