Unknown keywords
Frank Koormann frank.koormann at intevation.de
Mon Dec 11 09:43:54 EST 2000
Hi Thorsten,
* Thorsten Fischer (thfischer at mapmedia.de) [001211 14:24]:
> Ladies and gentlemen,
> I just updated my copy of the MapServer source code to the latest version from
> CVS. It compiles fine, as well as MapScript with the latest PHP version. But
> when I am trying to load a recently used .map file with the following
> definitions:
> SHADESET "symbols/shades.sym"
> MARKERSET "symbols/marker.sym"
> SYMBOLSET "symbols/line.sym"
> I got the following error message:
> msLoadMap(): Unknown identifier. (SHADESET):(7)
Yes, this has changed:
"Stephen Lime" <steve.lime at dnr.state.mn.us> wrote on  Wed, 11 Oct 2000:
| The new version uses a unified symbol file format which means you can
| store all symbols in one file. This allows for inline definitions
| (i.e. within a +mapfile) of symbols and more straight forward
| mapscript access. Anyway here's what's needed to switch:
|   1) SHADESET, MARKERSET, LINESET are gone and replaced by SYMBOLSET
|   2) the keywords SHADESET, MARKERSET, LINESET need to be removed from
|      symbol files, and so should the last END keyword
|   3) you can "cat" them all together
| That should do it.
Hope this helps.
Cheers,
    Frank
Frank Koormann                              http://intevation.net/~frank/
 Professional Service around Free Software         http://intevation.net/
 FreeGIS Project                                   http://freegis.org/
