problem with class expression
Stephen Lime
steve.lime at dnr.state.mn.us
Sun Feb 13 23:41:18 EST 2000
Peter: What you're trying to do (in both examples) is not possible. That's not to say that there isn't another way to do it. So, exactly what are you trying to do?
Steve
<<< "Peter H.M. Jacobs" <peter.jacobs at vs42.nl> 2/13 8:33a >>>
Hello,
I'm having trouble with a class expression. This is the case
LAYER
NAME Layer18Text # Straatnamen doorlopende wegen
TYPE ANNOTATION
STATUS DEFAULT
DATA Layer18Text
MAXSCALE 12000
LABELITEM "TEXTSTRING"
LABELANGLEITEM "TEXT_ANGLE"
LABELSIZEITEM "TEXT_SIZE"
CLASSITEM "TEXTSTRING"
CLASS
NAME SELECTED
!! EXPRESSION ([TEXTSTRING] eq [value]) #value is a cgi-variable from
MySQL It doesn't work !!
SYMBOL 0
COLOR 0 0 0
LABEL
ANTIALIAS
COLOR 0 0 0
FONT arial
TYPE TRUETYPE
SIZE 20
POSITION UR
END
END
CLASS
NAME NOTSELECTED
EXPRESSION /./ #the rest
END
END
If I try for example 'Markt' instead of [value] where I know that there is a
street Markt the expression is still not correct. I tried to use the feature
but this failed as well
FEATURE
POINTS [shpmid]
CLASS SELECTED
TEXT "TEXTSTRING]
END
Is there anyone who can help me
Regards,
Peter
