Tif an wld file problems
Doug Nebert
ddnebert at usgs.gov
Wed Feb 16 17:47:38 EST 2000
It is possible that you have a 24-bit TIFF file. It will only
render if it is 8-bit, or so I experienced a few months back.
Try again by saving the TIF as 8-bit and see what happens.
Doug.
Robert Chavez wrote:
> Greetings,
> I started fooling around with displaying tifs using mapscript and I'm
> having a problem rendering a tif image layer. I've run the demo package
> and displayed the landsat tif with mapserver just fine, so I know
> mapserver/script compiled with the tif libraries.
> The tif originally had a .tfw file so I changed the extension to
> .wld (it looks like this, units are in meters)
> 1.32301253030703
> 0.00000000000000
> 0.00000000000000
> -1.16784976858186
> 531694.70377556235000
> 181396.49239035073000
> After the script runs I get a blank .gif file as a result, no rendering of
> the tif in site. This leads me to believe there's an extent problem
> somewhere but I'm not sure where. The image should fit within the extents
> of the map file (see map file below), I should be getting something even
> if at a very small scale. I thought .tfw files were structurally identical
> with .wld files, or have I missed something?
> MAP
> NAME test
> SIZE 500 500
> EXTENT 520118.780 175873.500 534426.880 184948.500
> UNITS METERS
> SHAPEPATH "data"
> LAYER
> NAME stpauls
> TYPE RASTER
> STATUS ON
> DATA stpauls.tif
> END
> END
> Regards,
> Robert Chavez
> Perseus Project
> rchavez at perseus.tufts.edu
Douglas D. Nebert
Clearinghouse Coordinator
FGDC Secretariat Phone: +1 703 648 4151 Fax: +1 703 648-5755
Pager Messaging: http://fgdclearhs.er.usgs.gov/dougmsg.html
