Expression help
Fawcett, David david.fawcett at moea.state.mn.us
Fri Feb 18 16:23:57 EST 2000
The easiest way would be to pre-class them (1 - 8) in ArcView, Access, or some other database program.
I can't help you with the regular expressions, but if you search the archives at
http://mapserver.gis.umn.edu/cgi-bin/wilma/mapserver-users
you should be able to find some examples.
David.
David Fawcett
Minnesota Office of Environmental Assistance
> From: 	RAldridge[SMTP:RAldridge at linuxstart.com]
> Sent: 	Friday, February 18, 2000 2:44 PM
> To: 	mapserver-users at lists.gis.umn.edu
> Subject: 	Expression help
> Hello list,
> I'm needing help writing expressions to classify forest stands by age.  My shapefile includes a data item named "AGE2000" which is a numeric item representing the age fo the stand.  How do I need to set up classes if I want to represent the data in 10-year age classes.  Values of "AGE2000" range from 0 to 74.  Right now I have:
> LAYER
>   NAME standage
>   TYPE polygon
>   STATUS off
>   DATA stand110
>   CLASSITEM "AGE2000"
>   CLASS
>     NAME "0 - 9"
>     EXPRESSION "???"
>     SYMBOL 0
>     OUTLINECOLOR 0
>     COLOR 50 255 50
>   END
>   CLASS
>     NAME "10 - 19"
>     EXPRESSION "???"
