Problem with PROJ support in mapscript
Brent Fraser bfraser at geoanalytic.com
Sun Feb 20 20:23:19 EST 2000
I ran into that problem when compiling under Windows.
I changed the PROJ4 source from UV to ptUV.  I need
to contact Frank W. about integrating the change into
the "official" PROJ4 source...
Brent
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Saturday, February 19, 2000 10:03 PM
Subject: Problem with PROJ support in mapscript
> I have build a version of mapserv3.3_007 with PROJ4 support and
> trying to make mapscript have the same options, so I edited
> mapscript Makefile.PL to include the PROJ4 lib and includes,
> but when I try to "make" it, I get this error:
> In file included from ../../mapproject.h:7,
>                  from ../../mapshape.h:6,
>                  from ../../map.h:23,
>                  from mapscript_wrap.c:443:
> /home/cstuber/PROJ.4/src/projects.h:43: conflicting types for `UV'
> /usr/lib/perl5/5.00503/i386-linux/CORE/perl.h:841: previous declaration of
> `UV'
> make: *** [mapscript_wrap.o] Error 1
> Seems that both PROJ4 and PERL both declare the variable "UV"
> which are distinctly different.  I hate to hack up either, but
> may have to in order to get the mapscript to compile.  Any ideas
> or suggestions from the usergroup?
> Chris Stuber (mapsurfer)
> Silicon Mapping Solutions, Inc.
