No subject
bfischer at usgs.gov
Tue Jan 25 11:18:23 EST 2000
Mapserver Users,
I am in the processes of trying to install the mapserver software on a
UNIX platform (sun 5.6). Forgive me for asking what are probably simple
questions for most of you, but I have to learn somehow. I downloaded
LibTiff 3.5.4 and FreeType 1.3.1. I unpacked these two files and they are
in my home directory. Do I have to be in a specific directory before I
follow their install instructions? The install instructions say to just
type ./configure and then make. Can anyone provide additional information
that I may need before installing these packages?
The second question is associated with the mapserv software. I
unpacked the mapserv 3.3.005. When I unpacked it there was not a
mapserv.ini file in the directory to edit? I am also not very familiar
with UNIX setup, so is there anything in the Makefile that I should edit?
I also tried to run the make command from my home directory to see if it
worked. It did not seem to create any executables. Do I need to have the
mapserv directory in the cgi-bin before I type make?
Thank you for the help,
Brian Fischer
USGS WRD
2280 Woodale Dr.
Mounds View, MN
(612) 783-3133
