quakes.map in MapScript example?
John Frank
jrf at segovia.mit.edu
Wed Jul 12 13:20:07 EDT 2000
Hi -- I'm new to mapscript and am trying to run the mapquakes.pl example
locally. Does this line _create_ quakes.map or open an existing .map
file?
die $mapscript::ms_error->{message} unless $map = new
mapObj("mypath/quakes.map");
If it opens an existing one, is that file available somewhere? I see that
as of last December, new mapObj does not create an "empty" mapObj. Is
this still true?
Thanks! John
_____________________________________________________________________
John R. Frank Ecology! Solar! N9WLY www.mit.edu/~jrf
jrf at mit.edu cell: (617) 283-3999
jrf at joyce.eng.yale.edu fax: (253) 390-4974
jrf at 4dobe.com
To: <mapserver-users at lists.gis.umn.edu>
Subject: MapScript example...
From: "Stephen Lime" <steve.lime at dnr.state.mn.us>
Date: Tue, 16 Nov 1999 15:08:58 -0600
Content-Disposition: inline
Got a simple MapScript example running at
http://arachnid.dnr.state.mn.us/ms_test. It's a perl script that uses
remote data from the USGS (gathered using the perl Net::Finger module) to
plot the last 21 semi-major earth quakes around the world. I swiped the
world DEM from Doug Nebert's prototype, pretty image. Everything is
handled in perl using a few MapScript calls to manipulate map file
settings, draw the basemap, map the quake locations and to add a
timestamp. It may be slow depending on how busy the USGS servers are cause
each pan or zoom executes a finger request. In a production mode you'd
probably nab the data every hour or so and work from the copy, still no
need to create a shapefile. I'll glady share any details of this script.
Yes, documentation is in the works. I hope to have at least some up tonite
at the main MapServer site.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
