Mapimage problem
Sara Yurman
syurman at mindspring.com
Mon Jul 24 17:43:22 EDT 2000
I'm having a tough time getting the mapimage applet going. When I use
the mapimage.class in the mapimage.zip file it can't find the JIT
compiler. When I compile the .java code the applet won't start. I'm
running Redhat 6.2, with the Blackdown JDK and TYA JIT compiler. I had
read about the deprecation messages on the list, but understood that it
was known to work regardless. Would some change in my environment (a
different JIT perhaps?) do the trick?
I've listed relevant lines from my /etc/profile, as well as my error
messages below.
Many thanks for any help you can give me,
Sara
****************** My
Environment*********************************************************************
/etc/profile includes:
JAVA_HOME=/usr/local/jdk1.1.7
JAVA_COMPILER=tya
CLASSPATH=$CLASSPATH:/usr/lib/netscape/java/classes/java40.jar
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
echo $CLASSPATH produces:
.:/usr/local/jdk1.1.7/lib:/usr/local/jdk1.1.7/lib/classes.zip:/usr/lib/netscape/java/classes/java40.jar
********************Compiling
Mapimage***************************************************************
When I enter javac -verbose -deprecation mapimage.java I get:
TYA: #### 74087 byte for java/text/resources/LocaleElements.getContents
(()[[Ljava/lang/Object;)
[parsed mapimage.java in 74 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/applet/Applet.class) in
9 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/awt/Panel.class) in 1
ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/awt/Container.class) in
8 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/awt/Component.class) in
15 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/lang/Object.class) in 1
ms]
[checking class mapimage]
[loaded
/usr/local/jdk1.1.7/lib/classes.zip(java/awt/image/ImageObserver.class)
in 1 ms]
[loaded
/usr/local/jdk1.1.7/lib/classes.zip(java/awt/MenuContainer.class) in 1
ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/io/Serializable.class)
in 1 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/lang/String.class) in 5
ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/awt/Image.class) in 2
ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/awt/Dimension.class) in
2 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/awt/Graphics.class) in
3 ms]
[loaded
/usr/lib/netscape/java/classes/java40.jar(netscape/javascript/JSObject.class)
in 2 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/awt/Color.class) in 3
ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/awt/MediaTracker.class)
in 2 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/net/URL.class) in 5 ms]
[loaded
/usr/local/jdk1.1.7/lib/classes.zip(java/net/MalformedURLException.class)
in 1 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/io/IOException.class)
in 0 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/lang/Exception.class)
in 1 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/lang/Throwable.class)
in 2 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/lang/Error.class) in 0
ms]
[loaded
/usr/local/jdk1.1.7/lib/classes.zip(java/lang/RuntimeException.class) in
0 ms]
[loaded
/usr/local/jdk1.1.7/lib/classes.zip(java/lang/InterruptedException.class)
in 1 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/lang/Math.class) in 1
ms]
[loaded
/usr/local/jdk1.1.7/lib/classes.zip(java/util/StringTokenizer.class) in
1 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/lang/Integer.class) in
2 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/lang/Number.class) in 1
ms]
[loaded
/usr/local/jdk1.1.7/lib/classes.zip(java/lang/NumberFormatException.class)
in 1 ms]
[loaded
/usr/local/jdk1.1.7/lib/classes.zip(java/lang/IllegalArgumentException.class)
in 0 ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/lang/Double.class) in 1
ms]
[loaded /usr/local/jdk1.1.7/lib/classes.zip(java/awt/Event.class) in 4
ms]
TYA: #### 23417 byte for sun/tools/javac/SourceClass.compileClass
((Lsun/tools/java/Environment;Ljava/io/OutputStream;)V)
[loaded
/usr/local/jdk1.1.7/lib/classes.zip(java/lang/StringBuffer.class) in 4
ms]
[wrote mapimage.class]
mapimage.java:28: Note: The method java.awt.Dimension size() in class
java.awt.Component has been deprecated.
screenSize = this.size(); // nab the applet size
mapimage.java:133: Note: The method boolean mouseDown(java.awt.Event,
int, int) in class java.awt.Component has been deprecated, and
class mapimage (which is not deprecated) overrides it.
public boolean mouseDown(Event e, int x, int y) {
mapimage.java:139: Note: The method boolean mouseDrag(java.awt.Event,
public boolean mouseDrag(Event e, int x, int y) {
mapimage.java:150: Note: The method boolean mouseUp(java.awt.Event, int,
int) in class java.awt.Component has been deprecated, and cl
public boolean mouseUp(Event e, int x, int y) {
Note: mapimage.java uses a deprecated API. Please consult the
documentation for a better alternative.
5 warnings
[done in 567 ms]
*****************************Testing mapimage.class in the
appletviewer*********************************************************
Both versions produce the same messages.
The console says:
TYA 1.2 (for J117 / Linux). Copyright (c) 1997,98 The TYA Team
Contact The TYA Team via Albrecht Kleine <kleine at ak.sax.de>
TYA: #### 28930 byte for sun/applet/resources/MsgAppletViewer.<clinit>
(()V)
java.lang.UnsatisfiedLinkError: getWindow
at mapimage.init(Compiled Code)
at sun.applet.AppletPanel.run(Compiled Code)
at java.lang.Thread.run(Compiled Code)
The viewer says:
Start: applet not initialized
Sara Yurman
Spatial Focus, Inc.
syurman at spatialfocus.com
Voice: 404-378-0989 Fax: 209-254-9531
Type: text/x-vcard
Desc: Card for Sara Yurman
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20000724/2191052e/syurman.vcf
