Unable to access file???
Trevor Banister
trevor at banisterconsulting.com
Mon Jun 5 19:11:19 EDT 2000
Unless you compile under the Cygwin environment, you do need drive letters
and back slashes.
Trevor
-----Original Message-----
From: Stephen Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Monday, June 05, 2000 11:09 AM
To: mapserver-users at lists.gis.umn.edu; aborruso at spaziogis.it
Subject: Re: Unable to access file???
Some of the other users with more experience on NT can confirm or deny this
but
you may need to specify a drive letter too. NT seems very particular about
paths.
s.
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> <aborruso at spaziogis.it> 06/05/00 11:16AM >>>
Dear mapserver users,
I have begun to use mapserver few days ago. I have installed it on windows
Nt machine and It seems to work, but I'm not be able to view a very simple
map. I have begun to write a simple map file and then I have put this
string in my web browser (IE 5):
http://easyms/cgi-bin/mapserv.exe?map=/ms_demo/prova.map&mode=map.
The result is: msLoadMap(): Unable to access file. (/prova.map)
I have used the Path, relative to the CGI directory, but I have no
result.
This is my map file:
NAME EX1
EXTENT 74000 4775000 798000 5500000
SIZE 300 300
SHAPEPATH "/ms_demo/data"
LAYER
NAME "lakes"
DATA lakes
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 250 175 25
END
END
END
Please help me.
Thank you
