DBF file indexer?
Daniel Morissette
danmo at videotron.ca
Mon Jun 5 19:18:48 EDT 2000
Sean O'Hagan wrote:
> Hello list,
> Has anybody found a good utility for indexing those large DBF files that
> store the attributes for shape files? Is there such a beast?
There are a couple of Open source libs that will read/write DBF files,
but I have never found one that supports reading/writing .NTX (or .NDX?)
files... I would be interested in hearing about it as well if one
exists. I know that there is some format information at:
http://www.e-bachmann.dk/docs/xbase.htm
and there may be some in other places I guess.
If I had had the time I would have already implemented a lib to
read/write .NTX (or .NDX) files since I could use that myself... (or
maybe I should take the time and do it?!?)
However, here is another option if you want to do some coding... it's a
hack, but it would work! MapInfo stores its table information in a
format that is similar to .DBF files, and they store their indexes in
.IND files. I have written some C++ code to read/write MapInfo .IND
indexes as part of my lib to read/write MapInfo TAB datasets. One could
extract the code to handle MapInfo's .IND files and use that to index
his .DBF files.
Please keep us posted on whatever you find.
Daniel Morissette danmo at videotron.ca
http://pages.infinit.net/danmo/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
