MINFEATURESIZE bug?
Sean O'Hagan seano at metavera.com
Mon Jun 12 13:57:24 EDT 2000
Hello list:
Has anyone come across something similar to the following?
I'm labelling a map (which is fairly dense in streets) on which I noticed a
labelling error. The label for one of the streets had been pushed about 30
pixels to the left of where it should have been. I had not included
MINFEATURESIZE in the map file (found at the end of this message), so I
started playing around with it, starting at a high value and working
downwards finally reaching the value "1". At this point, the map looked
fine: the street in question was labelled properly, and all the streets were
labelled. However, when I set MINFEATURESIZE to 0 or remove it altogether,
the original problem returns.
Any thoughts, any more info required? Thanks,
Sean O'Hagan
Metavera Solutions, Inc.
192 Spadina Ave., Suite 405
Toronto, ON
M5T 2C2
Tel: (416) 504-8351
Fax: (416) 364-2636
Email: seano at metavera.com
LAYER
  NAME streets
  TYPE line
  STATUS default
  DATA "streets"
  LABELITEM street
  CLASS
    SYMBOL 0
    COLOR 199 199 199
    LABEL
      ANTIALIAS
      BACKGROUNDCOLOR 253 253 253
      COLOR 0 0 0
      FONT arial
      MINDISTANCE 700
      MINFEATURESIZE 1
      ANGLE auto
      PARTIALS false
      POSITION auto
      TYPE truetype
      SIZE 6
    END
  END
END
