drawLegend() and drawScalebar()
Zolla Michalak michalak at hwr.arizona.edu
Fri Jun 16 16:53:59 EDT 2000
I'm getting a segmentation fault for both drawLegend() and drawScalebar().
My code is:
$legendImg = $map->drawLegend();
$scalebarImg = $map->drawScalebar();
Should these methods work on thier own, or do I need to call something
else first like drawLabelCache(image)? ($map is a working mapObj)
I'm also having trouble with queryUsingRect(rect) and queryUsingPoint().
Has anyone had success with these methods? If so, would you mind sending
code examples?
Thanks!
-zm
