undefined symbol when using mapscript
imap at chesapeake.net
Tue Mar 7 00:55:45 EST 2000
Chris,
I'd recommending building the libraries locally, and link GD (possibly
others) statically. The dynamic libraries could be a problem, especially if
they are NFS mountes. Sounds like a questionable practice to me.
With 3.3.007 make sure that the mapscript "Makefile.PL" uses the
same -D defines as the mapserv Makefile. That one, I had to tweak
by hand.
That is about the only other suggestions I can make.
-Chris
Chris Fuhrman wrote:
> On Mon, 6 Mar 2000 imap at chesapeake.net wrote:
> > Chris,
> > go into the ms_3.3.007/mapscript subdir
> > perl Makefile.PL
> > make
> > make install (as root)
> This is how I initially installed it.
> At someone's suggestion (Thanks Steve! It's appreciated!), I've also
> copied libgd.a to /usr/lib but that didn't work either... :(
> > -Chris
> Chris Fuhrman
> cfuhrman at tfcci.com
> Public Encryption Key Available Upon Request
Chris Stuber (mapsurfer)
Silicon Mapping Solutions, Inc.
410-257-3187
