gd-1.8
Frank Koormann frank.koormann at intevation.de
Fri Mar 10 06:54:59 EST 2000
* Stephen Lime (steve.lime at dnr.state.mn.us) [000309 21:01]:
> The latest version of GD I had tried was 1.7.3. The jpeg stuff
> is brand new. MapServer won't use it anyway cause at the
> moment there is no way to toggle between PNG, JPG or BMP
> output with the new version. I imagine you could compile
> GD without JPEG support and it would probably work. I'll
> try it at home.
I have compiled mapserver 3.3-008 with GD 1.8 successfully.
Steve, you are right, GD has to be compiled without jpeg support.
Here the steps:
o in the Makefile of gd sources:
        - CFLAGS=-O -DHAVE_XPM -DHAVE_LIBTTF
        - LIBS=-lm -lgd -lpng -lz -lttf -lXpm -lX11
        - VERSION=1.8 # :)
o make libgd.a
o in the Makefile of mapserver:
        - As described in the GD Section, add -lpng and -lz to
          GD_LIB for png-support and set GD=-DUSE_GD_1_6
        - modify the path to libgd
        - #MAKE_GD=gd
                (to suppress compilation of gd-1.2 packed with the
                 mapserver)
o make
Thats it and it works fine for me (Since all other libs are available).
Regards,
        Frank
Frank Koormann			    	 http://intevation.net/~frank/
 Intevation GmbH				http://intevation.net/
 FreeGIS Project				http://freegis.org
 Institute of Environmental Systems Research 	http://www.usf.uos.de/
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20000310/05132e5a/attachment.bin
